Old 02-05-2018, 10:34 PM   #1
Cal3000
Drives: Panda FR-S
Atmospheric Pressure Sensor
Does anyone know where this is? When I log, I'm getting really low readings, like 74kpa and the car runs like crap. I wan't to try to replace it to see if it remedies the issue.
I'm on the Vortech kit.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 02-06-2018, 03:29 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
If memory serve correctly, the USDM cars use the CPC sensor to monitor atmo pressure. If you've repurposed the CPC sensor in EcuTek then the atmo pressure is derived from the MAP sensor I believe.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-07-2018, 01:10 AM   #3
Cal3000
Drives: Panda FR-S
Thanks. What exactly is the CPC sensor? Where is it located? What does CPC stand for. I'm searching online and I can't get any clear info. ;/
If the atmospheric pressure is derived from the MAP, then that would mean I may have a faulty MAP if the atm pressure is off?
Old 02-07-2018, 03:01 AM   #4
Hags86
Drives: Toyota GTS 86
Are you sure there an atmospheric pressure sensor at all? I thought there is just the MAP in the inlet manifold.
The MAP also has inlet air temp and there is a outside air temp (but this only makes it as far as the dash - probably gets CAN'd across the the ECU from there).
Hags86 is offline   Reply With Quote
Old 02-07-2018, 05:12 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Charcoal Purge Canister. That input is often reused on EcuTek for FlexFuel/WBO2 etc. There is an option in EcuTek to switch USDM pressure readings to "the rest of the world" setup. Some tuners may do this by default if they run tunes that may use the CPC input for FF.
US cars are different to the Euro/Aus cars. We don't have a CPC sensor so it uses the MAP sensor reading at startup.
Also, the MAP does not have Intake Air Temp. That's on the MAF sensor.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-07-2018, 05:25 AM   #6
Hags86
I stand corrected. Thank you. I knew there was a reason the MAF was still installed but didn’t recall what it was (I have a speed density tune and the ariflow part of the MAF is no longer connected).
Old 01-10-2022, 10:03 PM   #7
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
Where are these terminal blocks. I can' seem to find them and these instructions from Delicious Tuning don't give you much detail!
G_Rossney is offline   Reply With Quote
Old 01-11-2022, 11:18 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
"Use caution when connecting the auxiliary inputs to ensure the correct ECU pins are used."
Which oil pressure sensor, and which method of mounting? johnmk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 07-20-2016 12:01 PM
Broken Oil pressure sensor? Dream20b Issues | Warranty | Recalls / TSB 38 01-01-2016 06:02 PM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 03:28 AM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 02:41 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
