#57 | |
Drives: 2017 toyota 86
https://www.amazon.com/Sunway-Solar-.../dp/B01MYVUSRH https://www.amazon.com/Battery-Tende.../dp/B004Q83TGO https://www.survivalrenewableenergy....-charger-kits/ |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | why? (05-30-2019) |
#58 | |
Only happy when it rains.
Drives: series.blue
#59 | |
Drives: 2014 BRZ
My 51R battery is still chugging away. |
#60 |
Drives: '13 BRZ Limited
I ended up getting a Deka ETX15L. I'd used a Braille 14115 previously.
I 3D printed a spacer to center/hold it within the stock battery tray and raise it up just a little so I could use the stock tie-down. Also 3D printed a block to fit around the curved part of the stock hold down and to spread the load out over a wider area. Seems to work well - I'd done something similar with the Braille and it held up through 2 HPDE seasons and was going fine when I traded the car. The deka was way cheaper than the braille. $80 all in with the terminal adapters. Deka 11.8 lbs with mounting hardware. Stock 33.95 lbs with mounting hardware. More on the 3D parts here : https://www.ft86club.com/forums/show...&postcount=123 |
#61 | |
Drives: FRS
Until, I forgot my oft plugged in for 5 days. The charger became recalcitrant swapping into charge mode , after 24 hrs. the charger would still not go into charge mode, but it eventually went into store mode. Will report on reliability, after a long one of these -
#62 | |
Drives: FRS
Originally Posted by RFB View Post Mini Shorai - First 2 years of winter use up to 3 days parked and the car would start, but at arctic temps it was on a tender. Now I prefer a normal battery in the winter for peace of mind. Sixth year tracking and D/D, Shorai 5 lb. battery still going strong ! Quote:
Working normally now ! - Don't know about next winter, I may have to retire it for the season a little earlier !
#63 |
Drives: 13 White MT FR-S
Just got this for my track car, and I have been running the same format Lead/acid battery with less CCA for almost 2 years now.
![]() YTX12 case size 5.9 x 3.43 x 5.12 inches (LxWxH) 360 Cranking Amps 12 Amp Hours (Pb Eq) 3 lbs https://antigravitybatteries.com/pro...size/ytx12-12/
#64 | |
Drives: FRS
another year
As is the built block and supercharger, amazing!
#65 | |
Professional wrench
Drives: 2020 BRZ ST RS
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
#66 |
its been relocated to the top of the transmission tunnel under the dash in a gutted car.
| Tags |
| batteries, braille, deka, lightweight battery, shorai |
| Best lightweight battery still useful for DD'ing? | Keenercarguy | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 82 | 01-12-2026 02:58 PM |
| Lightweight Battery Tray | smg1138 | Tracking / Autocross / HPDE / Drifting | 9 | 05-02-2018 09:24 AM |
| FS: KC Machine lightweight battery mount with Shorai battery and charger | toeout | Engine, Exhaust, Bolt-Ons | 4 | 04-23-2017 12:07 AM |
| MAW lightweight battery kit. | Turn in Concepts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 08-24-2016 06:57 PM |
| Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package | KCMachine | Brakes, Suspension, Chassis | 111 | 10-08-2014 08:26 AM |
