Old 05-30-2019, 10:21 AM   #57
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by why? View Post
I don't have a place to plug in the battery tender, I keep waiting for solar powered tenders for car batteries to become a thing, but either I have been looking in the wrong places or it sadly does not exist yet. Anyone see one?
yes, every pound less will help.
All over the internet and amazon. 1st search resulted in many including these.
https://www.amazon.com/Sunway-Solar-.../dp/B01MYVUSRH
https://www.amazon.com/Battery-Tende.../dp/B004Q83TGO
https://www.survivalrenewableenergy....-charger-kits/
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
why? (05-30-2019)
Old 05-30-2019, 01:06 PM   #58
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by 86TOYO2k17 View Post
you are awesome. I've been looking and totally not finding.
why? is offline   Reply With Quote
Old 06-23-2019, 04:05 PM   #59
T-Steve
Drives: 2014 BRZ
Originally Posted by Jdmjunkie View Post
Is a Group 51R the stock summer battery? I found a different size somewhere on the TRD japan website. Will this fit the TRD battery tie down?
I'm not sure. I saw that Toyota used a 51R battery in a special JDM racing model. It might have had a name like "Griffin" or "Phoenix" or something like that.
My 51R battery is still chugging away.
T-Steve is offline   Reply With Quote
Old 02-28-2021, 05:23 PM   #60
86league
Drives: '13 BRZ Limited
I ended up getting a Deka ETX15L. I'd used a Braille 14115 previously.
I 3D printed a spacer to center/hold it within the stock battery tray and raise it up just a little so I could use the stock tie-down. Also 3D printed a block to fit around the curved part of the stock hold down and to spread the load out over a wider area.
Seems to work well - I'd done something similar with the Braille and it held up through 2 HPDE seasons and was going fine when I traded the car.
The deka was way cheaper than the braille. $80 all in with the terminal adapters.
Deka 11.8 lbs with mounting hardware.
Stock 33.95 lbs with mounting hardware.
More on the 3D parts here : https://www.ft86club.com/forums/show...&postcount=123
86league is offline   Reply With Quote
Old 05-11-2021, 08:08 PM   #61
RFB
RFB's Avatar
Drives: FRS
Originally Posted by RFB View Post
Mini Shorai -
First 2 years of winter use up to 3 days parked and the car would start, but at arctic temps it was on a tender. Now I prefer a normal battery in the winter for peace of mind.
Sixth year tracking and D/D, Shorai 5 lb. battery still going strong !
Nine years now, worked like a charm when I put it back in the car for this season, but a slightly slower crank.
Until, I forgot my oft plugged in for 5 days.
The charger became recalcitrant swapping into charge mode , after 24 hrs. the charger would still not go into charge mode, but it eventually went into store mode.
Will report on reliability, after a long one of these -
RFB is offline   Reply With Quote
Old 05-16-2021, 02:20 PM   #62
RFB
RFB's Avatar
Drives: FRS
Mini Shorai -
Working normally now ! - Don't know about next winter, I may have to retire it for the season a little earlier !
Old 05-16-2021, 09:58 PM   #63
ML
ML's Avatar
Drives: 13 White MT FR-S
Just got this for my track car, and I have been running the same format Lead/acid battery with less CCA for almost 2 years now.
YTX12 case size
5.9 x 3.43 x 5.12 inches (LxWxH)
360 Cranking Amps
12 Amp Hours (Pb Eq)
3 lbs
https://antigravitybatteries.com/pro...size/ytx12-12/
Old 01-03-2022, 02:12 PM   #64
RFB
RFB's Avatar
Drives: FRS
another year
Mini Shorai -
10 years tracking and as a DD, that damn little booger battery still goin strong !
As is the built block and supercharger, amazing!
Old 01-06-2022, 02:10 PM   #65
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
YTX12 case size
360 Cranking Amps
3 lbs
how did you fit it and secure it in your car? I really want to dump that huge stock battery, but I don't want to half -ass the install.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 01-06-2022, 03:58 PM   #66
ML
ML's Avatar
its been relocated to the top of the transmission tunnel under the dash in a gutted car.
batteries, braille, deka, lightweight battery, shorai
Best lightweight battery still useful for DD'ing? Keenercarguy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 82 01-12-2026 02:58 PM
Lightweight Battery Tray smg1138 Tracking / Autocross / HPDE / Drifting 9 05-02-2018 09:24 AM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 12:07 AM
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 06:57 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
