Old 01-19-2016, 05:58 PM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Best lightweight battery still useful for DD'ing?
What batteries are out there that are superior to the OEM rubbish but shave a few pounds?
I'm looking for the best weight reduction I can get on my BRZ that I STILL DAILY DRIVE (but also AutoX and will soon be tracking).
Thoughts?
Anyone daily drive on the FT-86 Speedfactory lightweight battery kit? ( http://www.ft86speedfactory.com/ft-8...l#.Vp690OtJqWW )
Keenercarguy is offline   Reply With Quote
Old 01-19-2016, 07:17 PM   #2
Keenercarguy
Mountain Runner
Anyone know if this will fit?
http://www.odysseybatteries.com/batteries/pc950.htm
Like anyone have ANY experience with these?
Old 01-19-2016, 10:07 PM   #3
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
I got this Shorai battery https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 which weighs about 3 pounds and was decently priced. It's been on since April 15 and hasn't given me any issues here in the Los Angeles weather.
BRZ_F is offline   Reply With Quote
Old 01-20-2016, 12:57 AM   #4
Keenercarguy
Mountain Runner
Also preferably looking for something drop in!
Old 01-20-2016, 02:40 AM   #5
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
No experience with the 950, but I had the PC925 and PC680 in other vehicles and loved them...plan to put a PC680 (the metal jacket version) in the FR-S when it's time to replace the battery.
I went with the largest Shorai in my FR-S and it died within 6 months...$200+ wasted...if you use a Shorai I would highly suggest keeping it on a battery tender at all times and watch battery voltage like a paranoid person, making sure it NEVER drops below 13.1 volts. Hawker Odyssey batteries are proven, reliable batteries in all situations from my experience while a Shorai is not. Shorai is too much hassle for daily driving, very easy to kill if you let the voltage drop below 13 volts...and the CCA rating is an 'equivalent', the actual amp throughput of the battery is MUCH lower in measurable output...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-20-2016, 02:41 AM   #6
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
http://store.kcmachine.com/collectio...shorai-battery
NLSP is offline   Reply With Quote
Old 01-20-2016, 04:10 AM   #7
Keenercarguy
Mountain Runner
$$_$$
Old 01-20-2016, 06:39 PM   #8
humfrz
....................I'm looking for the best weight reduction I can get on my BRZ that I STILL DAILY DRIVE (but also AutoX and will soon be tracking).
Thoughts?
For dependability, I'd suggest you stick with a good full sized battery.
I don't see how a 2-3 pound weight savings is going to make any significant difference on an autoX or track.
humfrz
Old 01-20-2016, 08:02 PM   #9
Keenercarguy
Mountain Runner
Well that Odyssey is a nice 10 pounds lighter... I just don't know if it'll fit yet
Old 01-20-2016, 08:24 PM   #10
FirstWinter
Drives: Car
Some members have the Shorai battery on their cars and have been fine even in freezing temperatures. It weighs about 3 lbs, but you will have to fabricate your own battery tie down. I know Odyssey also sells lightweight batteries and they sell a tie down kit as well along with it.
FirstWinter is offline   Reply With Quote
Old 01-21-2016, 12:52 PM   #11
DAEMANO
Time Traveller
It fits and is indeed a lot lighter. I've been running an Odyssey PC680 for quite some time now. Light, small, cheap, works. No issues.
http://www.batterymart.com/p-odyssey-pc680-battery.html
Old 01-21-2016, 02:57 PM   #12
Keenercarguy
Mountain Runner
Do you use the PC680MJT with te SAE terminals? Do you have to run any adapters on it? And how on earth do you get away with 170CCA???
Old 01-21-2016, 03:28 PM   #13
DAEMANO
Time Traveller
I use the standard PC680 (not the MJT) with Odyssey's SAE terminals. http://www.batterymart.com/p-odyssey-sae-terminals . No adapters needed.
The CCA arms race is just that. I mean really, how many CCAs does a starter motor on a 2.0L H4 really need? Answer, not nearly as many as people have been slowly led to believe (over years of PR). The Odyseey PC680 has started my car regularly without need for a jump even when I needed to crank it multiple times due to e85 cold start issues (which I resolved by adding 1 gal of 91 to my 10 gals of e85, not by adding a bigger battery). It just works. From what I understand some battery mfgs over rate their batteries CCAs, so now everyone is looking for as many CCAs as they can get, but not really needing it.
Old 01-21-2016, 03:42 PM   #14
Keenercarguy
Mountain Runner
And it just fits right in to the standard tray and bracket? Sounds pretty good to me... @DAEMANO
battery, daily driver, lightweight battery, track, weight reduction
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 06:57 PM
*BRZ Part Out* KCMachine lightweight battery xDanger_208x Engine, Exhaust, Bolt-Ons 2 03-31-2015 01:40 AM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
OEM shorter lightweight battery bracket? fstlane Tracking / Autocross / HPDE / Drifting 1 03-08-2014 12:26 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 02:01 PM
