Old 04-02-2018, 02:02 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Lightweight Battery Tray
I'm looking at getting a Shorai battery this season. Should remove about 30 lbs compared to the boat anchor I'm using now. Thing is I'm not sure how I'm going to actually mount it yet. Can the stock battery tray be used for such a small battery? If not, what are some good aftermarket trays to consider? Would like to find something that does the job without breaking the bank.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Leonardo (04-13-2018)
Old 04-02-2018, 02:32 PM   #2
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
depends on what is okay to you. a lot of people end up with spacers on a factory tiedown. There's the JDM oem small battery tray parts that are cheap but you still need the spacers to make that work.
From what i've seen if you want it to look nice you have to spend a chunk of change.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
smg1138 (04-02-2018)
Old 04-02-2018, 02:40 PM   #3
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
I did the p tuning small battery tray. It's real nice and works great. Doesn't work well with shori battery tender. So if you're going the super lightweight one that could be a big negative. You can check out pictures in my journal. But it's ~130. So spendy. There isn't a lot of options which sucks. A lot of people build their own with good success. Cost them 30 bucks or less. I'd prolly attempt to build my own if I did it again.
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
Old 04-02-2018, 02:54 PM   #4
smg1138
smg1138's Avatar
What kind of spacers would I need for the factory tie down to work?
Old 04-02-2018, 04:46 PM   #5
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I have 2 half inch zip ties around the battery fed through the old battery tray mounting support (the metal part on the car, not the plastic tray).
The Shorai is a solid battery, so a tray doesn't do anything for it. I first tried the spacers route but the battery is so small that without fabricating something all my attempts were less secure than I wanted. My giant zip ties have worked flawless for over a year, 30+ autox events, and 12+ trackdays.
I think these are the pack I'm using: https://www.homedepot.com/p/Commerci...D-10/203531933
they are rated to 175lbs and are more than sufficient to hold a 2lb battery securely.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
Old 04-02-2018, 08:30 PM   #6
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
There's a few idea's I found when trying to do the same:
http://www.ft86club.com/forums/showthread.php?t=32544
http://www.ft86club.com/forums/showthread.php?t=120937
http://www.ft86club.com/forums/showthread.php?t=110285
http://www.ft86club.com/forums/showthread.php?t=100268
bmacfrs is offline   Reply With Quote
Old 04-03-2018, 09:02 PM   #7
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I have a Shorai LFX14L2-BS12 for sale if you are interested.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 04-13-2018, 12:17 AM   #8
smg1138
smg1138's Avatar
So, it passed tech being tied down with zip ties? That’s my main concern.
Old 04-13-2018, 12:59 AM   #9
14stu
14stu's Avatar
I've passed tech with 3 different autox groups, and annual tech for my region's SCCA (our chief of tech runs tech for Pro Solos and has been a tech inspector at nationals, and is super stringent).
The battery isn't going anywhere, and those zip ties are too thick to cut with scissors without significant difficulty (I use tin snips to cut them).
The batteries are solid state, so it's not like anyone is worried about them leaking and the size is small enough that there isn't anything within 4" of the battery.
You could go with a worm gear setup or fabricate a bracket if you are worried but I haven't had any issues after a year (30+ autocrosses and 15 trackdays).
smg1138 (04-13-2018)
Old 05-02-2018, 09:24 AM   #10
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Yep the second link is what I did last year with some simple home depot parts. Super solid with this setup and only adds about a 1lb to the battery.
SuperTom is offline   Reply With Quote
Lightweight battery that fits the stock tray and tie down? SPCorBUST Engine, Exhaust, Transmission 40 01-11-2021 10:46 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Transmission 61 09-30-2016 11:24 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Engine, Exhaust, Bolt-Ons 18 06-04-2014 01:07 PM
PTUNING Billet Aluminum Lightweight Battery Tray Mrc@ptuning Tracking / Autocross / HPDE / Drifting 5 12-07-2013 02:01 PM
