Old 01-14-2013, 12:11 PM   #1
Turn in Concepts
Turn in Concepts's Avatar
MAW lightweight battery kit.
Did some test fitting for Motive Autowerks last weekend on their new BRZ/FR-S battery.
Battery is 11.7 lbs.
Battery box is around 7 oz.
Uses inserts in the stock lower bracket to hold it down so you'll pass tech.
Turn in Concepts is offline   Reply With Quote
Old 01-14-2013, 12:12 PM   #2
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Looks good, how much does the kit retail for?
Old 01-14-2013, 12:26 PM   #3
Turn in Concepts
Honestly, I'm not sure yet. I'll have to talk to them about pricing, but most likely in the ballpark of your typical lightweight battery trays out there.
Old 01-14-2013, 12:28 PM   #4
ATL BRZ
ATL BRZ's Avatar
What brand is the battery? Specs on it?
Old 01-14-2013, 01:32 PM   #5
Turn in Concepts
It's an Odyssey PC545.
The Following User Says Thank You to Turn in Concepts For This Useful Post:
Shankenstein (01-25-2013)
Old 01-14-2013, 03:49 PM   #6
ATL BRZ
ATL BRZ's Avatar
Cool, here are the specs:
545 cranking amps for 5 seconds
495 cranking amps for 10 seconds
420 cranking amps for 20 seconds
Short circuit current over 1200A
18 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
Length 6 7/8"
Width 3 1/4"
Height 5 1/8"
Weight 11.7 lbs
Odyssey design:
2 year full warranty
Rugged Drycell sealed design
Military grade
Vibration resistant
60% more starting power
Deep discharge reserve power
2 year storage life
8-12 year design life
Can be mounted flat or upright
Retails for $137
The Following 6 Users Say Thank You to ATL BRZ For This Useful Post:
20valvewynn83 (04-08-2013), Anthonytpt (08-26-2013), jliongh (09-24-2016), makinen (08-26-2013), Shankenstein (01-25-2013), Slartibartfast (01-16-2013)
Old 01-25-2013, 12:13 PM   #7
ATL BRZ
ATL BRZ's Avatar
Any updates on availability and pricing yet?
Old 01-26-2013, 11:13 AM   #8
Turn in Concepts
Not yet. We asked for some changes to be made.
Old 01-27-2013, 09:26 PM   #9
Wasabi
おい、だいじょうぶ?
Wasabi's Avatar
Drives: BRZ Limited 6 Speed
would you recommend using this battery in the winter time?
Wasabi is offline   Reply With Quote
Old 01-28-2013, 10:51 AM   #10
Turn in Concepts
funny that you should ask that. We've purposely been leaving ours outside on then going out and starting it every few days to see how it does.
So far it seems to be doing just fine.
Wasabi (01-28-2013)
Old 01-28-2013, 11:27 AM   #11
BadCompany235
#TrackAddicts
BadCompany235's Avatar
Drives: The Dipped Car
comparison to FT86Speedfactory??? that kit is around $250...
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance
Chadbee Photography / Passion Moves Photography
BadCompany235 is offline   Reply With Quote
Old 01-28-2013, 12:06 PM   #12
Turn in Concepts
Here is the details on the battery:
14Ah
CCA - 185
Old 01-28-2013, 12:38 PM   #13
OrbitalEllipses
Drives: Attitude
Those CCA pale in comparison to the stock Group 35. Have you considered a box for everybody's favorite, the PC680?
Old 01-28-2013, 01:19 PM   #14
Turn in Concepts
we have, and we discussed it at length with MAW when we asked for this design. Given the emphasis on the weight on this car, even from the manufacturer we opted to go with a lighter battery that we think will still meet the FA20 owner's needs.
funbeatsfast (02-02-2013)
≥≥≥ WEIGHT LOSS PROGRAM ≤≤≤ Lightweight battery kit. New Years Resolution Complete!!! FT-86 SpeedFactory Brakes, Suspension, Chassis 52 05-26-2013 11:19 PM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 10:05 PM
Awesome idea, lightweight battery/catch can combo JoeBoxer Engine, Exhaust, Transmission 21 12-31-2012 06:11 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
