#29 | |
Drives: Crapcan
If it doesn't come off I would say a clamshell would be the best bet. I don't think a jaw'd puller will work well. Just don't bite the crank. https://www.harborfreight.com/bearin...tor-63662.html
#30 |
Gonna need to do a compression test after all this for sure bro
Sent from my ONEPLUS A5010 using Tapatalk |
#31 |
Drives: 22 BRZ limited
Have you checked the timing yet to see if it's out and how far?
#32 |
#33 |
Drives: Pearl White 2014
Well the new parts are ordered, I'll check the timing before i put everything back together obviously.
#34 | |
Drives: 2013 frs base
Trouble is here is that he has get it all back together to do a compression test. |
#35 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | blsfrs (12-11-2021) |
#36 |
Persona Non Grata
Drives: '15 BRZ (WRB)
I guess he could replace the sprocket, time the cams, and do a leakdown on each cyl spinning the crank between. It's not that far beyond where he is and certainly not a complete button-up - compression test - teardown cycle.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | blsfrs (12-12-2021) |
#37 |
I don't think it jumped timing, missing two teeth doesn't allow the chain to really move, it's still engaging multiple teeth at any given point in the rotation.
#39 |
#40 |
Teeth broke because i jammed the wodruff key into them like a total ding dong.
#41 |
#42 |
Persona Non Grata
With the timing cover off it's easy enough to check.
| BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD | MJones_RB | Engine, Exhaust, Bolt-Ons | 3 | 03-31-2021 03:07 AM |
| [GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt | reeves | Engine, Exhaust, Bolt-Ons | 0 | 08-22-2018 07:01 PM |
| Anyone had luck installing Perrin Crank Pulley on AT | efactor84 | Engine, Exhaust, Transmission | 11 | 06-04-2015 11:21 AM |
| 10mm bolt broke when installing Supertek hood dampers | merino_frs | Northern California | 6 | 08-11-2014 10:13 PM |
| Crank pulley bolt | tech4pdx | Engine, Exhaust, Transmission | 5 | 03-04-2013 08:18 PM |
