Old 03-04-2013, 02:05 PM   #1
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Crank pulley bolt
I don't remember reading much on whether the crank pulley bolt should be replaced when going with aftermarket pulleys. I have the 3-piece GFB set installed and it has been on the car for almost a month with no issues. No wobble, no leak. The stock crank pulley bolt was re-used. I keep hearing differing opinions on whether this part should be replaced or not. It's only $8-$9 and would probably make me feel better if I did replace it. I'm worried about bolt stretch/fatigue.
Thoughts?
tech4pdx is offline   Reply With Quote
Old 03-04-2013, 02:15 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Thoughts?
Re-used mine on my Perrin, 3K miles later, it's fine.
There are some folks who suggest replacing any bolt that you take out, not just crank pulley ones. I guess if you're typically checking your pulley with every maintenance to make sure it's still on securely, you should be fine with the stock bolt.
Old 03-04-2013, 04:14 PM   #3
Jlin
Drives: FRS
Thoughts?
same kit, reused the stock one, no problems so far
Jlin is offline   Reply With Quote
Old 03-04-2013, 04:56 PM   #4
tech4pdx
Make love
tech4pdx's Avatar
Thanks for the feedback guys. I will stick with the stock bolt.
Old 03-04-2013, 05:41 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
If the bolt is torque to yield you'll have to replace it. This bolt is torqued to a specific torque setting, not an angle so it's very doubtful you'll have to replace it. I know one companies instructions say to replace it if you reach the final torque setting with less then 45 degrees between the last two steps. This has got to be a typo. If you go over a certain amount it could easily indicate the bolt is yield (breaking). Not to mention 45 deg is pretty arbitrary.
All in all, you should be fine.
Old 03-04-2013, 08:18 PM   #6
tech4pdx
Make love
tech4pdx's Avatar
Thanks
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 10:51 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
