| Northern California NorCal |
10mm bolt broke when installing Supertek hood dampers
Hey guys,
So I was installing the Supertek hood damper kit and I was almost done when the 10mm bolt from the drivers side broke off. The threaded part is still inside the hole and the top half is in my hand. Any suggestions on how I can take it out? Thanks guys! |
Drives: 83 Toyota Supra, 16 FR-S RS2.0
If there are any threads showing, you could 'carefully' put a pair of vice-grips on to unscrew it or perhaps grind a slot to take it out with a screwdriver. If the bolt is broken off in the threaded area, you will have to use an easy-out after drilling a small hole into the bolt leftovers. I am in Modesto, I may be able to help or give additional advice with a pic or in person (I have most of the tools and perhaps a small enough easyout).
Eric G |
Drives: FRS(sold), AP2, R35, FJC, ED9
if u cant get to any exposed threads and its deep inside and you dont have access to easy outs. you might be able to keep threading it in until it falls out the other side. if the hole is a thru hole you might be able to take a regular drill bit to bite into it to push it out the other side.
#4 | |
Drives: Grocery cart
Make sure you use a left hand thread drill bit, if not you will be screwing in the broken bolt even further in . If you can do this.. get smaller bolt that will cover the exposed bolt, and get super glue and stick it on there for a few min.. then try to work it back out.
SOLD: 2014 BRZ Limited WRB 6 Speed.
#5 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Listen to this guy^^ |
Thanks for the input guys @mkiisupra I'm also in modesto. I'll try your advice and if all fails I could definitely use your helping hand. Thanks a lot fellas
Drives: 2013 FRS (Silver)
I've broken a valve cover bolt before. I drilled a hole big enough to jam a torx screwdrive in, and backed out the broke off thread.
| Broke the stock overpipe bolt :/ | Sniper2606 | Engine, Exhaust, Transmission | 44 | 04-26-2015 01:19 AM |
| 10mm bolt broke | merino_frs | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 08-11-2014 08:45 PM |
| Supertek hood dampers | mightyt73 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-21-2014 11:41 PM |
| ***SuperTek Carbon Hood Dampers - Install DIY*** | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-18-2014 08:16 AM |
| Looking for Hood Dampers meant for CF hood. | Vicious LED | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-31-2012 02:47 AM |
