Old 11-18-2021, 03:53 PM   #1
Wingnutt
Drives: Pearl White 2014
POP while installing crank bolt, now CEL and TCS!
So I installed a fluidampr crank pulley today.
When removing the pulley didn't just come off, the crank shaft pulley spacer came with it.
having never pulled the crank pulley before I didn't know if this was normal or not, so I popped the crank pulley off the spacer and slid the spacer back in after wiping it down to make sure it was clean.
I installed the fluidampr pulley and started tightening the crank pulley bolt with a torque wrench. I started at 30#, then 50# then when on the way to 75# there was a POP and the bolt got real easy to turn.. I backed the bolt out and checked to make sure I didn't break it, it was fine.
I put the bolt back in and torqued it down but stopped at 50#. praying something just slipped and that I didn't actually break anything.
So I put everything back together and went for a drive.. car has a noticeable rattling sound now, like there is a loose bit bouncing around somewhere and I got the CEL and TCS lights on "limp mode" after about 10 min of driving... feels like the timing might be off.
what did I do? is there a piece like a key or something in there that is now rattling around? did I break something in there off?
Wingnutt is offline   Reply With Quote
Old 11-18-2021, 04:02 PM   #2
Ashikabi
Ashikabi's Avatar
Hmmmmmm at first I thought you stripped your crank but it kinda sounds like you might have jumped the timing chain. Is your belt still riding nice on the pulley? Did you ever finish torqueing it? Is the spacer loose?
Old 11-18-2021, 04:22 PM   #3
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Pray to the subie gods you aligned the small key to the adapter
IsaiahW is offline   Reply With Quote
Old 11-18-2021, 04:36 PM   #4
Wingnutt
RUH ROH!
Ill take it back apart and check it out tomorrow. but yea it feels out of time, and that would explain the limp mode.
Old 11-18-2021, 05:48 PM   #5
Ashikabi
Ashikabi's Avatar
Zoinks yo
Old 11-19-2021, 01:51 PM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Ouch
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-19-2021, 09:12 PM   #7
humfrz
Weren't nutten wrong with your OEM crank pulley -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Calum (12-03-2021), MrSkubi (11-24-2021), NoHaveMSG (11-22-2021), ZionsWrath (11-22-2021)
Old 11-19-2021, 10:03 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
looks like there's about to be...
Old 11-21-2021, 02:53 PM   #9
Wingnutt
I'm having hell getting the spacer back out, is there a tool or a way to get that bugger out without destroying it? I can get out about 1/2 inch out but thats it.
Regarding destroying it though, where do you order a new one? I will probably go ahead and order a new spacer and the key as well. having trouble finding a place that sells them though..
Old 11-22-2021, 11:17 AM   #10
Capt Spaulding
Persona Non Grata
Probably not. Mines fine. I still would like to put a Fluidamper on it. Just cuz - cool. I do have a certain weakness, though, for fixin things what ain't broke (until I fixed em).
The Following User Says Thank You to Capt Spaulding For This Useful Post:
humfrz (11-22-2021)
Old 11-22-2021, 12:03 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It it is damaged, you have bigger issues then just the spacer. The spacer drives the oil pump, that is why it has two flats on it, so you possibly had it misaligned with that. Or as mentioned above, you may have had it misaligned with the key. I would shine a flashlight down when you get the spacer off and make sure you didn't damage the timing chain sprocket and key.
Did you check to see what the CEL's were?
Old 11-22-2021, 12:09 PM   #12
Ashikabi
Ashikabi's Avatar
I'm gonna guess that damaging the oil pump is likely
Old 11-22-2021, 12:35 PM   #13
Wingnutt
Well i found and ordered a replacement spacer and O ring.
Still can't get the old one out, it comes out about 1/2 inch and sticks, but now that a new one is on the way I'll try getting more.. assertive with it.
Old 11-22-2021, 12:36 PM   #14
jrhudson
Drives: 2016 scion frs
Okay first, DO NOT TURN ON YOUR CAR ANYMORE until you get it checked out/fixed. If you need to move it, roll it or tow it.
I had a similar issue that ended in catastrophic failure. You may have gotten lucky but cant be sure until you look into the crank pulley hole. That keyway holds the engine in time, hearing rattling could be the timing chaining out of time.
When you heard the pop noise was it mechanical at all? Like metal on metal?
Last pic is what you should see if the keyway is still in its spot.
Edit: I forgot to mention just like you OP, i had a hell of a time taking out the crank spacer, it was stuck and this was when my motor was sitting on an engine stand. I kept trying to pull on by wiggling it side to side.
jrhudson is offline   Reply With Quote
The Following 3 Users Say Thank You to jrhudson For This Useful Post:
bcj (11-22-2021), blsfrs (11-23-2021), NoHaveMSG (11-22-2021)
BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD MJones_RB Engine, Exhaust, Bolt-Ons 3 03-31-2021 03:07 AM
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
Anyone had luck installing Perrin Crank Pulley on AT efactor84 Engine, Exhaust, Transmission 11 06-04-2015 11:21 AM
10mm bolt broke when installing Supertek hood dampers merino_frs Northern California 6 08-11-2014 10:13 PM
Crank pulley bolt tech4pdx Engine, Exhaust, Transmission 5 03-04-2013 08:18 PM
