Old 11-23-2021, 12:45 AM   #15
Wingnutt
Drives: Pearl White 2014
Thanks for all the advice, i still haven't got the space out yet. Too busy a work today.
Wingnutt is offline   Reply With Quote
The Following 6 Users Say Thank You to Wingnutt For This Useful Post:
Calum (12-03-2021), Capt Spaulding (11-24-2021), churchx (11-26-2021), humfrz (12-03-2021), Irace86.2.0 (12-11-2021), soundman98 (11-23-2021)
Old 11-23-2021, 10:57 PM   #16
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Misaligned key and keyway. Its a woodriff key so it can rock. Probably busted the timing chain gear on the crank. Something similar happened to me
Rabrooks is offline   Reply With Quote
Old 12-02-2021, 02:30 PM   #17
Wingnutt
Alright finally got a chance to mess with it today, the new spacer and o ring came in and I was able to get the old spacer out, it actually came out pretty easy.
I got in there with an endoscope and it looks like everything is still intact, no damage or anything.
The one thing I didn't find was the old key, hopefully its chilling down in the oil pan or somewhere safe.
Like a said the car RAN after I did the screw up so there is nothing catastrophically broken, it just felt sluggish/out of time.
So should I just get a new key, install everything and give it a go? any other things I should check etc etc?
Again I appreciate all the feedback and help
The Following User Says Thank You to Wingnutt For This Useful Post:
EAGLE5 (12-02-2021)
Old 12-02-2021, 02:35 PM   #18
Wingnutt
Weren't nutten wrong with your OEM crank pulley -
I got the fluidampr to HOPEFULLY mitigate some of the vibration I'm getting after installing a lighter weight flywheel
The Following 2 Users Say Thank You to Wingnutt For This Useful Post:
EAGLE5 (12-02-2021), humfrz (12-02-2021)
Old 12-02-2021, 02:51 PM   #19
Wingnutt
Ok so im trying to order the key but it doesent seem to exist...
https://parts.austinsubaru.com/a/Sub...10-013-02.html
where can I find one? what is its specific name? It doesen't even show up on the diagram or parts list.
EDIT:
Found it after calling a round a lot, kudos to austin subaru..
the part number for the key is 804505060.
Old 12-02-2021, 02:56 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Uhhhh. That looks kinda FUBAR.
If the key is missing, then it is out of time.
Old 12-02-2021, 03:06 PM   #21
Wingnutt
So what do I need to do other than order a new key? it will just slide in correct?
Old 12-02-2021, 03:08 PM   #22
Wingnutt
and is THIS the correct key?
Old 12-02-2021, 03:17 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is an EJ engine. You can tell because it has a pulley for a cog belt. I do not know if it is the same key as our engine which is an FA.
If they key came out, I would want to double check the engine is in time before just putting one in. The keyway looks a bit mashed up to me. If it was running before and will run now then I wonder if you just sheared the top portion of the key off and it is still jammed in there. It is too hard to tell for the pictures. Either way, I would personally want to pull the timing cover and check it.
If I get a minute I will pull the crank pulley off my engine sitting on the stand and take some pictures to compare, but that timing gear looks messed up to me.
Old 12-02-2021, 03:23 PM   #24
Wingnutt
Yea the car ran but felt out of time.
Old 12-02-2021, 03:31 PM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I will try to grab some pictures to compare today. The engine is just sitting down in the warehouse and is accessible so I should be able to pop it off and take a peak.
EAGLE5 (12-09-2021)
Old 12-02-2021, 03:58 PM   #26
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I agree with @NoHaveMSG. At the very least, the timing cover has to come off to examine the extent of the damage. You might need to run compression test to make sure that you didn't bend any valves. I hope you get lucky, find the key and put it all back together.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
dpfarr (12-02-2021), NoHaveMSG (12-02-2021)
Old 12-03-2021, 12:04 PM   #27
Weren't nutten wrong wif the OEM flywheel.
(jest ah messen wich ya, I hope you get your car up and running - )
Old 12-09-2021, 03:38 PM   #28
Wingnutt
Alrighty update time!
I got the timing cover off today and..
2 teeth broken off of the front timing chain sprocket.. so now I guess Ill order that.
EDIT: so what is the best way to get the old sprocket off? will it just slide off once the tension is off the timing chains?
BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD MJones_RB Engine, Exhaust, Bolt-Ons 3 03-31-2021 04:07 AM
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 08:01 PM
Anyone had luck installing Perrin Crank Pulley on AT efactor84 Engine, Exhaust, Transmission 11 06-04-2015 12:21 PM
10mm bolt broke when installing Supertek hood dampers merino_frs Northern California 6 08-11-2014 11:13 PM
Crank pulley bolt tech4pdx Engine, Exhaust, Transmission 5 03-04-2013 09:18 PM
