Old 11-07-2021, 10:25 PM   #57
CSG Mike
CSG Mike's Avatar
Originally Posted by Stonehorsw View Post
Are you sure about track width? According to Subaru is increased 0.4inches, also RLCA has a new part number.
RLCA length was the same when measured with a tape measure.
The Limited trim's wider wheels would... push track width wider as well.
Old 11-07-2021, 10:27 PM   #58
CSG Mike
CSG Mike's Avatar
2022 BRZ Limited 18x7.5 wheels should clear 17-20 PP brakes without issue.
Needs a 5mm spacer to clear the CSG V2 Brembo BM4 caliper.
pinoy_dorifto (11-11-2021), timurrrr (11-08-2021)
Old 11-08-2021, 05:55 PM   #59
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What's different is the rear quarter configuration. The width of the quarter is the same, but due to the new shape and mounts, wheel fitment will be affected.
Please add more details to this thread!
https://www.ft86club.com/forums/showthread.php?t=147495
Originally Posted by Lincoln Logs View Post
Is the bolt pattern the same for the wheels?
Yes, but some wheel/tire combos that have no issues on 1st gens might have issues in the rear on 2nd gen, see the thread referenced above.
They're 7.5" wide, same as Performance Package on '17-'20's though?
Old 11-08-2021, 11:52 PM   #60
Brock H.
Drives: 2022 BRZ, Red
Originally Posted by Code Monkey View Post
How about RUCA?
Subaru Part catalog confirms same RUCA as previous gen.
Catalog also shows that the rear knuckle and rear subframe are specific to the new gen, but the Wheel Bearing assembly is the same. I'm assuming that the track width difference is coming from either or both of those.
Almost makes me think the changes to the rear may have affected camber gain or other alignment geometry, which may have an effect on the wheel fitment difference @trippinbillies40 is reporting. But its just a theory at this point
Brock H. is offline   Reply With Quote
The Following 2 Users Say Thank You to Brock H. For This Useful Post:
Code Monkey (11-09-2021), Stonehorsw (11-09-2021)
Old 11-10-2021, 04:24 PM   #61
CSG Mike
CSG Mike's Avatar
Some ACS footage showing a clean lap, as well as comparisons to the 1st gen car in LONG straights.
ZDan (11-11-2021)
Old 11-10-2021, 04:49 PM   #62
TommyW
TommyW's Avatar
Drives: '13 Whiteout
So Mike, 1st Gen with header and Zach tune compared to stock Gen 2 as far as performance?
TommyW is offline   Reply With Quote
Old 11-10-2021, 05:00 PM   #63
CSG Mike
CSG Mike's Avatar
Roughly yes. Not quite 1:1 as the powerbands wont be identical, but pretty darn close.
nikitopo (11-11-2021), TommyW (11-10-2021)
Old 11-10-2021, 05:17 PM   #64
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
You gave me an idea. Let's see where it goes.
How much Ethereum do you want to send me a CSG goodie bag?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 11-10-2021, 05:27 PM   #65
ayau
Drives: Some rust bucket
hey mike, i dont think i've seen you do a brain dump of your thoughts on the 2nd gen yet. specifically, in stock trim and how it compares with the 1st gen.
Old 11-11-2021, 02:10 PM   #66
CSG Mike
CSG Mike's Avatar
I haven't. Still gathering my thoughts and need to spend more time in the car.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
ayau (11-11-2021), Espi (11-11-2021), Jdmjunkie (11-11-2021), jflogerzi (11-11-2021), nikitopo (11-11-2021), Yoshoobaroo (11-11-2021)
Old 11-11-2021, 03:08 PM   #67
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any updates on the oil temp situation?
I presume you've switched to 5w-30 oil?
The car still only has the OEM oil cooler?
How much cooldown does the engine require throughout a typical track session, compared to e.g. tires and brakes?
Do you plan to keep the OEM oil cooler, or install a separate radiator?
The Following User Says Thank You to timurrrr For This Useful Post:
Old 11-11-2021, 03:51 PM   #68
CSG Mike
CSG Mike's Avatar
No updates.
Still on factory oil.
Still on the factory oil heat exchanger
Zero additional cooldown needed.
Unknown, as I don't know what's needed.
If you'd like to fund the R&D, I can probably get all of this done quickly, within a week. I'd need to hire a CANBUS expert to sniff and identify the relevant channels, as well as a fabricator to figure out an oil-air mounting solution, factory cooler delete, thermostatic plate solution, and line routing. I'm sure some time can be saved by having new existing GReddy and Jackson oil cooler kits on hand, but that alone is already easily a $5000 bill.
Remember, I have to work a job too, and only have so much resources to put towards this car.
timurrrr (11-11-2021)
Old 11-11-2021, 04:08 PM   #69
ayau
No updates.
there's no oil and pressure data on the dash? is there factory oil temp sensor?
does ecutek from 13-17 work, or does the ecu need to be jailbroken to access the ecu tables?
Old 11-11-2021, 04:24 PM   #70
CSG Mike
CSG Mike's Avatar
Only temp, and it's one bar that reads from 120F to 340F, so the resolution is quite garbage. Once we have a digital reading to equate to positions on the bar, it'll be more useful, but at the moment, nothing.
Ecutek doesn't even recognize the ECU. None of my existing hardware reads any data out of the ECU other than base channels.
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
