Old 11-04-2021, 05:24 PM   #43
CSG Mike
CSG Mike's Avatar
Old 11-04-2021, 08:20 PM   #44
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
It looks great Have you tried running those pads with Ti Shims.. with my '19 SS 1LE I could see a dramatic drop in temps (~40 F IIRC) .. I was worried that if would affect the rotor life (being a heavy car) but it didn't . Most likely because it eliminates the fade and so the pad drag in braking zones. Anyhow, congrats again!
glamcem is offline   Reply With Quote
Old 11-04-2021, 08:22 PM   #45
jflogerzi
jflogerzi's Avatar
Get those TIPS ready guys
CSG Mikes Wallets
Tips Appreciated!
BTC: 3Ho17Er6avcWr6LNmy6LqFqidwx6pi7RJi
ETH: 0x6e225F34A948fA0EAB50E8137a01c4539e6e4204
@CSG Mike
2013 Series 10 FRS #553
Old 11-04-2021, 09:48 PM   #46
CSG Mike
CSG Mike's Avatar
The fluid degradation is such that shims won't do anything. Plus, CSG pads already have thermal insulation built in!
The next weakest point is the rotor, but all this just verifies what we know from the 13-20 cars!
This is how my rotors used to look regularly, before I put on a BBK. https://www.instagram.com/p/Bki4Vc_Ay5Q/
Old 11-04-2021, 09:52 PM   #47
CSG Mike
CSG Mike's Avatar
CSG Mikes Wallets
Tips Appreciated!
@CSG Mike
Better than doordash!
Old 11-05-2021, 01:49 PM   #48
glamcem
glamcem's Avatar
In my case shims made a huge, quantifiable difference most likely because the aftermarket pads (Raybestos ST47/ST45s) didn't have the insulation layer as you mentioned.
As you may be already aware Motul RBF 600 lowered their dry/wet boiling temp ratings so I switched to Castrol SRF a couple years ago that and shim combined solved most of my fade issues.
See below for before (2017 Camaro SS 1LE - same pads and Motul RBF 600 without ti shims) and after (2019 Camaro SS 1LE Castrol SRF and Ti shims) ..of course it's a much heavier, faster car with very sticky tires but same conditions and track. After that I didn't have to see purple calipers after a first event anymore
Are 1st gen and 2nd gen brake system is interchangeable? I am planning to get BBK, coilovers, anti roll bars for now and am not planning to touch the engine so it would be amazing if many of the things are the same so I wouldn't have to wait for them to become available
Old 11-05-2021, 01:59 PM   #49
dreamwonder
Drives: GR86 2022
Mike, would you have a rough idea if the factory or csg brembos clear the 18in oem wheels?
dreamwonder is offline   Reply With Quote
Old 11-05-2021, 02:04 PM   #50
CSG Mike
CSG Mike's Avatar
We'll know Saturday probably, when I have a chance to have both my BRZs next to each other with a lot of tools at ACS.
Old 11-05-2021, 02:04 PM   #51
CSG Mike
CSG Mike's Avatar
@glamcem the reason I use multiple temp stickers, is that the trailing end of the caliper will be significantly hotter than the leading edge; that side has more exposure.
Based on your temp sticker location, your temps may be higher than you realize. 50C spread isn't uncommon across the caliper, especially if you're using the SC3R in wider sizes.
Old 11-05-2021, 04:49 PM   #52
glamcem
glamcem's Avatar
You're correct. Because of that I tried to use the sticker on the piston side but because of the curvy shape of that it didn't stick well.. to confirm the delta I used a laser temp gun and it was still remarkably lower than my previous readings. Discoloration of the caliper and the improved brake fades were also noticeable.
Using multiple temp stickers make sense, I will try that next time.
How about the brake/brake lines compared to Gen 1, are those interchangeable? TIA
Old 11-05-2021, 06:49 PM   #53
CSG Mike
CSG Mike's Avatar
After an extensive measuring session, we've determined that the rear is dimensionally identical, when it comes to track width, RLCA, etc.
What's different is the rear quarter configuration. The width of the quarter is the same, but due to the new shape and mounts, wheel fitment will be affected.
Old 11-05-2021, 07:37 PM   #54
Code Monkey
Drives: Subaru BRZ
How about RUCA?
Code Monkey is offline   Reply With Quote
Old 11-07-2021, 01:03 PM   #55
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Are you sure about track width? According to Subaru is increased 0.4inches, also RLCA has a new part number.
Stonehorsw is offline   Reply With Quote
Old 11-07-2021, 10:24 PM   #56
CSG Mike
CSG Mike's Avatar
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
