Old 10-31-2021, 06:32 PM   #1
Mike's 2022 BRZ
Let a new journey begin.
I have no idea what direction I'll eventually take this car, but I'm certain it'll involve some sort of performance driving! Y'all need to crack the whip and regularly tag me here, so I keep the post updated.
???? - Call Irvine Subaru and request that they order me a new BRZ the moment it is available, and leave a standing deposit. I've already purchased many cars from them, and they know I'm committed.
28 Oct, 2021 - Get a message from Irvine Subaru that my BRZ has arrived and is ready for pickup. Unfortunately have to work and won't make it.
29 Oct, 2021, 9PM - Took delivery after hours, courtesy of Asher who stayed late so I could sign for the car. I attempt to connect Ecutek and an AIM Solo DL when I get home to see what data I can get. Neither are able to at this time. 6 miles on the ODO at this time.
30 Oct, 2021, 4AM - Show up at CSG to swap in CP brake pads, Endless brake fluid, and swap the terrible factory lug nuts for some RAYS Lug Nuts. CSG lug nuts have been backordered for a while, so I opted for the next best thing.
30 Oct, 2021, 6AM - hit ACH (Angeles Crest Highway) on the way up to Streets of Willow for 86CUP, to feel the car out.. Car is slightly understeery as expected. I get worried that I'm perhaps cycling the tires a bit much. I also spend some time bedding the brakes, and progressively increase engine load and RPM, to do simulated dyno break-in.
30 Oct, 2022, 8AM - I get to SoWS, dump everything out of the car in a rush, and head on track. The car definitely feels softer than before. It's easily a superior everyday driver compared to the 1st gen car.
2 Nov, 2022 - CSG FLA V2 Prototypes installed, corner balanced, and aligned.
4 Nov, 2022 - Car is being flogged at SpeedVegas, not by me. Brakes validated. Coilover may get another revision.
6 Nov, 2022 - Auto Club Speedway with 86CUP. Easily hit 6th gear, even with a passenger. Very used stock tires able to stay flat in oval without issue.
8 Nov, 2022 - Dropped car off at OEM Audio+
27 Nov, 2022 - STR38 private track day at Buttonwillow. Suspension testing with very, very dead tires.
12 Dec, 2022 - 86CUP Round 12. Mixed drivers. CP pads showing about 4.5mm of wear after ~7 hours (rounded down) of track use.
Old 10-31-2021, 06:38 PM   #2
Old 10-31-2021, 06:39 PM   #3
I made it all of 7 hours stock.
On the way home.... I thought the rearview mirror was atrocious and I need another JDM frameless. I debated taking the one off of my 17 BRZ. Errors were made; I should have pre-emptively ordered.
Old 10-31-2021, 06:40 PM   #4
Less than 12 hours after getting the car, it's at Streets of Willow. 146.5 miles on the clock.
Old 10-31-2021, 07:37 PM   #5
Angrypuppy
Drives: 2022 BRZ Limited on order
What’s your suspension plan?
Angrypuppy is offline   Reply With Quote
Old 10-31-2021, 07:39 PM   #6
TBD.
I'll probably try all 3 of:
- CSG spec Flex A
- CSG prototype
- JRZ RS1
Old 10-31-2021, 09:12 PM   #7
PulsarBeeerz
Drives: JRSC BRZ SOLD
Nice! Can't wait till its broken in and hits the CSG dyno and NA development begins; in time of course.
PulsarBeeerz is offline   Reply With Quote
Old 10-31-2021, 11:25 PM   #8
jflogerzi
jflogerzi's Avatar
Subbed! I am committed to the gen 1 platform
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-31-2021, 11:50 PM   #9
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
TBD.
- CSG spec Flex A
- CSG prototype
- JRZ RS1
Designed with the '22 in mind, or bolt on from the 12-20 cars? Either way, super excited to see where this goes!
villainous_frx is offline   Reply With Quote
Old 11-01-2021, 02:31 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Sub'd. Good luck!
Old 11-01-2021, 07:55 AM   #11
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Where did you get those temperature indicator stickers and what brand/model are those?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 11-01-2021, 08:04 AM   #12
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Are the rear tow points the same distance apart? Asking for Slambert twin hitch compatibility.
dragoontwo is offline   Reply With Quote
Old 11-01-2021, 03:04 PM   #13
vin61k
vin61k's Avatar
Drives: 2018 BRZ 6MT
sheeeeeesh
vin61k is offline   Reply With Quote
Old 11-02-2021, 02:35 AM   #14
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Wondering if your current CSG Spec Touring 86 Comp Exhaust by MXP fits?
Asking for a friend
Lightened is offline   Reply With Quote
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
