Old 11-02-2021, 04:22 PM   #15
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
stripped bolt head
Ok, please explain how on earth you break an oil plug?
stripped the bolt head... That's broken enough for me. ...granted, I wasn't wearing rubber gloves so that was probably the real issue
Originally Posted by 7 skulls View Post
....Torque wrenches are my friends, at work and at home.
I thought I knew how to fix cars until I learned about finer things called torque wrenches. After rotating the tires on my (then) '87 MR2, I tested the grip by driving ...mph down a freeway only to have 3 bolts snap off all at the same time. The one bolt that hung on saved my life. Torque wrenches are the beginning of tools you'll need if you repair your vehicle yourself. Agreed.
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
CockpitCruiser is offline   Reply With Quote
The Following User Says Thank You to CockpitCruiser For This Useful Post:
7 skulls (11-02-2021)
Old 11-02-2021, 04:46 PM   #16
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Didn't break mine, but I did replace it. It started to get rounded off and had the painted crush washer corroded on causing leaks even with a fresh one stacked on, so $2 later at Subaru I got a new one. When I bought a fresh oil pan from Toyota, it came with a drain plug bolt... and a painted on washer .
villainous_frx is offline   Reply With Quote
Old 11-02-2021, 11:40 PM   #17
Maybe some of these folks are using a HD impact wrench - set on HI.
Opie (11-03-2021)
Old 11-03-2021, 12:13 AM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Or plyers. I would think you would strip all the threads in the oil pan before you rounded the head? I guess if there is a will, there's a way.
humfrz (11-03-2021)
Old 11-03-2021, 01:39 PM   #19
OR ........
Well, it is a "plug" is it not?! -
Old 11-03-2021, 01:52 PM   #20
7 skulls
Drives: 2014 scion frs
Reminded me of this old meme...
7 skulls is offline   Reply With Quote
The Following 4 Users Say Thank You to 7 skulls For This Useful Post:
ddevl_86 (05-19-2023), humfrz (11-03-2021), soundman98 (11-03-2021), whataboutbob (11-03-2021)
Old 11-03-2021, 09:40 PM   #21
CockpitCruiser
Custom Title
Drives: GT86
... if there is a will, there's a way.
I use my teeth
Old 11-04-2021, 03:46 AM   #22
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by CockpitCruiser View Post
I use my teeth
Kinky
The Following User Says Thank You to x808drifter For This Useful Post:
CockpitCruiser (11-04-2021)
Old 11-04-2021, 01:19 PM   #23
CockpitCruiser
Custom Title
Drives: GT86
Originally Posted by x808drifter View Post
Kinky
No more bolt
No more drop
No more oily fingers
Just easy peasy...
soundman98 (11-05-2021)
Old 11-05-2021, 02:09 PM   #24
Ernest72
Nothing against fumoto, but never had an issue with an oil pan bolt on numerous cars and 100s of oil changes.
With a fumoto valve you are at risk of a gang of anarchists that go around with a special tool opening fumoto valves on parked cars, just because.
Old 11-05-2021, 02:18 PM   #25
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
lol ok, cause my car totally looks like it has one on there.
This is as crackpot crazy as the people who think someone will hand out drugs on Halloween
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
CockpitCruiser (11-11-2021)
Old 11-05-2021, 02:28 PM   #26
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Those of us with a '22 won't worry about it. It has a cover over the drain.
The Following User Says Thank You to dragoontwo For This Useful Post:
CockpitCruiser (11-14-2021)
Old 11-05-2021, 08:57 PM   #27
soundman98
ProCrastinationConsultant
soundman98's Avatar
um, so who's to stop anyone with a Gator Grip socket running around a parking lot and doing it to every other standard drain plug?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
CockpitCruiser (11-14-2021), x808drifter (11-05-2021)
Old 11-06-2021, 11:52 AM   #28
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Only special tool needed with the FuMoto is a low deck height trolley jack.
That'd be a bit noisy and conspicuous.
Don't park with one side up on the curb?
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 10:59 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
