Old 10-13-2021, 03:33 PM   #29
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The 2nd gen has about the same weight and whp as Honda S2000.
I believe they are classed CS/STR?
Don't see any obvious reasons why 2nd gen should be classed differently from S2k.
The Following User Says Thank You to timurrrr For This Useful Post:
racingfool (10-14-2021)
Old 10-13-2021, 04:59 PM   #30
whataboutbob
AutoX-10/10ths every run
Originally Posted by trippinbillies40 View Post
I kinda struggle with this one as I can see both sides of the argument. Obviously I want it classed so I can go play where I have a chance of winning. But, it could really upset any ST class it goes into. The hard part is STU is the fastest class, but it's also the most diverse meaning the biggest risk of major course dependency. I don't think it will be an overdog over an ND2 in STR but it could be...
Best solution? Autocross needs more classes. Let's make STX2 just for the ZD8s. Maybe STZ? STGRZ?
I'll just show myself to the door.....
SSCST .... lol
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
RT-BRZ (10-13-2021), trippinbillies40 (10-13-2021)
Old 10-18-2021, 01:46 PM   #31
Eric1855
Drives: LP DSP / CSP '13 BRZ
I think STR makes the most sense if they don't want it to be an immediate overdog. While STU is "theoretically" faster than STR it rarely ever is. This year at Nats the top cars in STU and the top cars in STX were all within a few tenths, and all 4s off the STR pace. Both courses were very STR friendly, but still...I think the car would quickly become one of the top cars to have in STU.
STR could use the help in numbers, the car technically fits the "philosophy" of the class too, makes sense.
The differences in the ND1 and ND2 are very small in ST trim. A lot of the power gains came from the changes that let it safely go from 6800 redline to 7200 redline that many people were already tuning to in the ND1, so full tilt builds the power wasn't that different, nowhere near where a Gen 1 vs 2 Twin will end up.
Eric1855 is offline   Reply With Quote
The Following User Says Thank You to Eric1855 For This Useful Post:
DocWalt (10-27-2021)
Old 10-26-2021, 10:57 PM   #32
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
I believe STU is the best fit for 2022. The class needs numbers and this would help out. STU results are between STX and STR, and that's where the car will probably finish IMHO.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 2 Users Say Thank You to Simmons For This Useful Post:
Goingnowherefast (10-27-2021), strat61caster (10-27-2021)
Old 10-27-2021, 09:12 AM   #33
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
STR all day long, it's a no brainer.
STU is going to get faster and then the twin will be *buried* so may as well just bite the bullet now and move the ND to STU where it's always belonged and then class the new twins in STR... or just let the new twins battle it out with the ND anyway.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
Kelse92 (10-27-2021), RT-BRZ (10-27-2021)
Old 11-03-2021, 12:18 AM   #34
Jucostud
Rookie
Jucostud's Avatar
Drives: '22 BRZ Premium MT6
Twins in STU with 18x10's and 285's could be interesting lol.
I'm hoping for STX
Jucostud is offline   Reply With Quote
Old 11-03-2021, 12:01 PM   #35
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm hoping for STX
18x10s and 285s won't fit, so....
As someone that just competed in STR pretty successfully and owns an STX car... new twin belongs in STR.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
justint5387 (11-22-2021), Kelse92 (11-04-2021), RT-BRZ (11-03-2021)
Old 11-03-2021, 06:24 PM   #36
Jucostud
Rookie
Jucostud's Avatar
*Fit*
We could probably make it work with some Strano poke
Old 11-04-2021, 10:46 AM   #37
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
*Fit*
lol I also agree with this, as long as the car is not slammed to the ground.
I was looking at mine on the alignment rack last night thinking, "there's a lot of room in here for me to poke a bunch of tire out in the rear." In front things are more limited but possibly do-able.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 11-04-2021, 11:22 AM   #38
Jucostud
Rookie
Jucostud's Avatar
Camber makes anything fit in the front xD
Old 11-18-2021, 04:32 PM   #39
Banannie
Drives: 2022 BRZ, 2008 S2K CR Delete
Rumor is that the SAC and STAC are reluctant to class the Gen 2 cars for the 2022 season. I'll encourage everyone to write a letter asking for them to be classed. I'm not going to campaign for you to ask for any class in particular, just that they need to find a home in both Street and Street Touring. The easy button is CS and STR because they're least likely to be major overdogs there.
http://crbscca.com/
Thanks!
LOL Dave
1) SAC will class the car for 2022. Hopefully decided at the December meeting - anyone who gets a car please go autocross it and give the SAC data! It's 1000000% not a slam dunk in either logical class it could fit in (CS vs. DS).
2) I can't say definitively, but the STAC may not class it for 2022. There's not a mandate to class ST cars immediately, there is a drive for more stability given higher investment than Street, and there's a hesitation to have a repeat of the ND quick classing in STR that disrupted the class... and STX isn't broken. Gathering more data and seeing how the cars respond to the aftermarket before classing it makes a lot of sense...
Banannie is offline   Reply With Quote
The Following 4 Users Say Thank You to Banannie For This Useful Post:
DocWalt (11-20-2021), Locust (11-18-2021), MacSpeed (11-18-2021), strat61caster (11-18-2021)
Old 11-18-2021, 05:36 PM   #40
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by Banannie View Post
LOL Dave
Any chance it goes BS?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 11-22-2021, 09:56 AM   #41
Banannie
Uh, why? It's possibly slower than the ND in CS so what would make you think BS? It fits there worse than DS...
DocWalt (11-22-2021), MacSpeed (11-22-2021), strat61caster (11-22-2021), timurrrr (11-22-2021)
Old 11-23-2021, 11:57 AM   #42
Locust
Custom User Title
Locust's Avatar
I'm just asking if there is any chance of that happening. Sounds like 0%, good.
LOCUST
Instagram:
LocustAutoX
Sponsors:
SCCA AutoX Classing... Roadcone Tracking / Autocross / HPDE / Drifting 13 10-21-2014 05:02 PM
Carbon fiber hood & SCCA classing TimR Tracking / Autocross / HPDE / Drifting 21 06-17-2014 12:27 PM
AutoX and classing chappys4life Tracking / Autocross / HPDE / Drifting 16 02-20-2013 03:38 PM
Autocross next wknd for me! Interesting response re: classing.. MarkRacerX Tracking / Autocross / HPDE / Drifting 42 06-18-2012 01:52 AM
