Old 06-30-2021, 04:01 PM   #1
Wingnutt
Drives: Pearl White 2014
Skid plate bolt sizes?
What size bolts are used to hold the factory aluminum skid plate on? I'm missing a few of both the small and larger bolts.
2014 FR-S
Wingnutt is offline   Reply With Quote
Old 06-30-2021, 04:48 PM   #2
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Per subaru parts diagram, the 12mm larger bolts are M8x16 and the 10mm bolts are M8x16. If this link works you can verify the sizes.
https://parts.bowsersubaru.com/a/Sub...10-572-01.html
Brz866 is offline   Reply With Quote
Old 07-01-2021, 01:33 AM   #3
jflogerzi
jflogerzi's Avatar
2014 FR-S
take one down to local hardware store. You can find something that matches pretty closely
2013 Series 10 FRS #553
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt Gopherboy6956 Engine, Exhaust, Transmission 16 11-23-2017 12:56 PM
Bolt sizes for 2012 86 can anyone help? tweedbean Engine, Exhaust, Transmission 3 01-02-2017 02:40 PM
Stock exhaust bolt/nut sizes? l0aded Engine, Exhaust, Transmission 8 08-03-2015 07:09 PM
Voltex wing bolt sizes BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-16-2015 09:31 AM
Common bolt sizes ayau Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-09-2013 04:24 AM
