Old 01-08-2013, 08:09 PM   #1
ayau
Drives: Some rust bucket
Common bolt sizes
I figured this would be helpful for anyone working on their cars.
The common bolt sizes for the BRZ/FRS are the following.
8mm, 10mm, 12mm, 14mm, 17mm, 19mm
Old 01-08-2013, 10:35 PM   #2
gmookher
Once you add all your aftermarket stuff, you need the full metric set..
gmookher is offline   Reply With Quote
Old 01-09-2013, 03:24 AM   #3
Panman
Panman's Avatar
Drives: 86 GTS
Correct - eg. Speed Bleeders to fit the twins = 11mm
Panman is offline   Reply With Quote
Common sense!! tintumz22 Off-Topic Lounge [WARNING: NO POLITICS] 31 05-22-2016 07:24 AM
Common problem? BRZ NA Scion FR-S / Toyota 86 GT86 General Forum 35 10-28-2012 05:25 PM
Is P0108 (MAP sensor) common ? regal Issues | Warranty | Recalls / TSB 0 10-06-2012 12:21 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Is this kind of mark up common? Surge101 Scion FR-S / Toyota 86 GT86 General Forum 30 07-01-2012 12:33 AM
