Old 06-09-2013, 02:45 AM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Stock exhaust bolt/nut sizes?
Hey I am swapping my downpipe on my aftermarket exhaust out back to my stock but seemed to misplace my old bolts and nuts. Does anyone know the stock bolt/nut sizes?
Also as long as the bolts and nuts go flush it shouldnt matter if the hole on the midpipe is slightly larger as long as the bolt/nut is torqued to the correct amount correct?
Thanks
l0aded is offline   Reply With Quote
Old 06-09-2013, 09:16 AM   #2
Bullnettles
Drives: Scion FR-S 2013
Subscribed, because yesterday I went to check the nuts on my header after the 100 miles and I'm missing a header nut.
Bullnettles is offline   Reply With Quote
Old 06-09-2013, 10:43 AM   #3
FirestormFRS
Wild random guess M6 1.25
FirestormFRS is offline   Reply With Quote
Old 06-09-2013, 03:31 PM   #4
l0aded
Addicted
l0aded's Avatar
Well I'm going to the store and buying a bunch of nuts and bolts. Will report back when I figure it out.
Old 06-09-2013, 04:16 PM   #5
Bullnettles
If you can wait, I could send you mine for the overpipe. Just did it a few days ago, and think I reused the old instead of the replacements.
Old 06-09-2013, 09:06 PM   #6
l0aded
Addicted
l0aded's Avatar
Not sure if it was 100% tight but I used a M8 - 1.25 - 35mm
Old 11-16-2014, 12:35 AM   #7
akahenry
akahenry's Avatar
Drives: '18 STi
Can you confirm that's correct? :o
akahenry is offline   Reply With Quote
Old 11-19-2014, 10:01 PM   #8
l0aded
Addicted
l0aded's Avatar
Sorry it was too long ago to make sure =X
Old 08-03-2015, 06:09 PM   #9
nor cal frs
nor cal frs's Avatar
Drives: whiteout scion frs
Anyone know the answer?
nor cal frs is offline   Reply With Quote
Broke the stock overpipe bolt :/ Sniper2606 Engine, Exhaust, Transmission 44 04-26-2015 01:19 AM
Stock exhaust sizes Aaron_blatherwick Engine, Exhaust, Transmission 0 05-30-2013 10:57 PM
Stock Sway Bar Sizes On FRS? gbgracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 04-25-2013 09:22 PM
Common bolt sizes ayau Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-09-2013 03:24 AM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
