Old 01-02-2017, 07:51 AM   #1
tweedbean
tweedbean's Avatar
Drives: White GT86
Bolt sizes for 2012 86 can anyone help?
Hi guys I wondered if anyone could help me out with a couple of bolt sizes. I need the six bolts that hold the inlet manifold to the head and the 4 bolts that hold the injector heat shields on. I have the Crawford power blocks I am removing that use longer bolts so I need to order the stock ones but they are on back order until march which is to long to wait. So I wondered if anyone knew the correct size and length or someone could measure the stock bolts for me please? Apparently the heat shield bolts are different lengths on each side of engine.
I can then order generic bolts From eBay rather than wait three months for the same thing from Toyota.
tweedbean is offline   Reply With Quote
Old 01-02-2017, 09:48 AM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I would go look for Subaru parts not Toyota. The bolts are common to many different Subaru models and they would have them in stock.
http://parts.subaru.com/a/Subaru_201...10-050-01.html
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-02-2017, 11:06 AM   #3
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Intake Manifold M8 x 30, 12mm hex flange head.
Brackets... Not sure, still looking through my old docs.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 01-02-2017, 01:40 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Toyota part numbers:
.: Stealth 86 :.
Kodename 47 DJ:
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
Stock exhaust bolt/nut sizes? l0aded Engine, Exhaust, Transmission 8 08-03-2015 06:09 PM
Voltex wing bolt sizes BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-16-2015 08:31 AM
Common bolt sizes ayau Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-09-2013 03:24 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
