Old 11-21-2017, 12:29 AM   #1
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt
Does anyone have a good resource on a 27mm socket that will actually fully fit around the spacer bolt that holds the Mocal thermo plate down with the oil cooler spacer?
Every time I have to unhook the oil cooler, I have to sacrifice a bolt because I cannot find a 27mm socket that will fit around the whole bolt.
Anyone else have this problem?
Here's a pic of the plate and bolts for reference:
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 11-21-2017, 05:00 PM   #2
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Harbor Freight sells a deep impact socket set that goes, I think, to 32mm. Check and confirm the 27 is in the set. I suspect it is.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-21-2017, 05:11 PM   #3
Gopherboy6956
I did check harbor freight - the depth isn't the issue - it's the room around the sides of the of the bolt where i'd need a thinner than average socket to fit. I'm just wondering if anyone else has this issue?
Old 11-21-2017, 06:13 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Thinner on the outside diameter correct?
Because the galley prevents you from sliding the socket over the bolt?
Google this specifically. "Thin Wall Deep Socket"
Hope this helps.
https://www.google.com/search?q=27+m...hrome&ie=UTF-8
Old 11-21-2017, 06:27 PM   #5
Gopherboy6956
Hmm - I did google thin wall sockets, but it wasn't any thinner than my current 27mm. Maybe it's because it's a 12 point, where 6 points are thinner...
Old 11-21-2017, 07:14 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.sears.com/craftsman-27mm-...p-00934081000P
Old 11-21-2017, 08:41 PM   #7
DarkSunrise
DarkSunrise's Avatar
I took a 27mm socket to a local machine shop and asked them to thin out the wall on a lathe. Really quick/cheap/simple. I think I paid ~$10.
2022 BRZ Build
2013 FR-S Build
Old 11-21-2017, 09:06 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^this^^
If you get the good-buddy deal then toss your guy an extra twenty. If you keep going back, they'll eventually have to invoice the work. I have a pile of one-off special tools.
Old 11-21-2017, 09:39 PM   #9
ls1ac
ls1ac's Avatar
as a last ditch effort I have chucked up a socket in a drill (if socket is too big or drill to small, us an extension) and used a bench grinder to thin out the wall by running the drill to make the grinding even.
(chucking the socket in a lathe and using a tool post grinder is the right way.)
Old 11-22-2017, 12:26 AM   #10
Gopherboy6956
Fucking Brilliant. I don't know why I didn't think of this. I have a decent bench grinder - I don't know why this never donned on me.
Thanks guys!
Old 11-22-2017, 10:11 AM   #11
Submarinesonce
Drives: Frs
wear some safety glasses....
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 11-22-2017, 01:54 PM   #12
ls1ac
ls1ac's Avatar
a couple of things to consider:
do it slowly to not overheat and loose the temper.
do it at an angle to save as much steel as you can and still get into the casting.
and finally, grind or belt sand the end of the socket to remove the easy start taper, you want as much engagement as possible.
Old 11-22-2017, 03:05 PM   #13
Gopherboy6956
I'll just be glad to not have to destroy a bolt everytime i need to take it out.
Old 11-22-2017, 05:26 PM   #14
Ultramaroon
not playing cards
Quoted for emphasis.
As you grind the workpiece, dip it in water often to keep it cool. Blue means it got too hot.
First remove the easy start taper. Then chamfer for clearance.
Thanks, ls1ac!
BRUH!
It doesn't need to be much more than hand tightened. Consider it similar to tightening the oil filter itself.
As the oil filter is tightened, it adds to the compressive force of the adapter gasket.
FS: parts: ace header, FBM Mocal oil cooler, perrin CAI, and seibon VS style.. Howardwei Engine, Exhaust, Bolt-Ons 21 06-22-2017 10:51 PM
Smallest bolt on spacer? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 08-21-2015 03:06 PM
Perrin Crank Pulley, Mocal/Setrab Oil Cooler, Mazworx Header Flanges smellslikecurry Engine, Exhaust, Bolt-Ons 21 06-30-2014 06:50 PM
Mocal/Mishimoto Bolt On Oil Cooler Setup, SOLD Philly758 Engine, Exhaust, Bolt-Ons 6 12-11-2013 04:47 PM
