Old 06-12-2021, 03:13 PM   #1
czellers
czellers's Avatar
Drives: 2K19 GT86
TPMS at highway speeds
Weirdest thing ever.. im on aftermarket wheels and randomly all of the sudden now after being on the highway at about 60 ish mph for about 10-15 min I get a TPMS light stays on solid... next startup it's gone and doesn't come back just beating around town, only at sustained highway speeds....
czellers is offline   Reply With Quote
Old 06-12-2021, 06:38 PM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
You don't happen to have a full size spare tire with a TPMS sensor in it?
LimitedSlip is offline   Reply With Quote
Old 06-13-2021, 12:09 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
If the brains don't get a signal from one or more sensors, the light doesn't immediately come on, it waits about 15 minutes or so. If your lower-speed trips around town are short enough duration, the light may not come on. You might have a dead sensor.
Old 06-13-2021, 01:47 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
One time is a fluke, 3 times is a pattern. Let it ride
Old 06-14-2021, 08:53 AM   #5
Jappy
Drives: Subaru 86
I agree with you.
Jappy is offline   Reply With Quote
Old 06-14-2021, 09:28 AM   #6
Ohio Enthusiast
Drives: 2018 BRZ
It's distance, not time - around 20 miles (might be 30 KM, which is 18.6 miles). Have the same with my summer set (no TPMS) vs. winter set (stock wheels with TPMS).
Then the TPMS light would blink at startup and persist for the drive, and then randomly (perhaps picking up the TPMS from the winter set in the basement?) would stop until the next time I'm driving more than 20 miles.
Ohio Enthusiast is online now   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Ultramaroon (06-14-2021)
Old 06-14-2021, 12:49 PM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Get a scanner and check the batteries for the sensors?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-14-2021, 01:25 PM   #8
Yup. Distance. My original sensors are in my winter wheels in the garage. I'm good to go until I pass 20 miles.
Those transmitters have some serious range!
Calum (06-14-2021), Wally86 (06-14-2021)
Old 06-14-2021, 03:01 PM   #9
This seems to be one of those strangely inconsistent things with these cars. When I switch to my winter tires my light comes on within a block. When I go back to the summer ones with the sensors then it goes out as I am leaving the shop lot. I never have a delay in time or distance either time.
Old 06-14-2021, 06:27 PM   #10
Where do you store your summers? Sounds like they're kept out of range.
Old 06-14-2021, 07:37 PM   #11
At the shop about 20 miles away. But the light turns on about a block away from it when I go to the winters. It almost instantly goes off when I go to the summers. None of this driving for X distance stuff I keep seeing. Probably less than 50 feet.
Old 06-14-2021, 09:13 PM   #12
I dunno, man. You're special.
Dzmitry (06-15-2021), Tcoat (06-15-2021)
Old 06-15-2021, 07:54 AM   #13
I am not the only one that has said this. Both the FRS and the 86 did the same thing. I will try to remember to check distance/tie when I go back to the winters.
Ultramaroon (06-15-2021)
Old 06-15-2021, 08:31 AM   #14
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
So lots of people have said that you're special?
2013 with no TPMS sensors so I have no valuable input here. I wonder if there's a difference in light operation between subaru and toyota/scion or maybe pre/post facelift.
Actually TCoat, since you've had both pre and post you could speak to if there was any change when you switched cars (for toyota at least)
CrowsFeast is offline   Reply With Quote
BRZ not stable at highway speeds unplugged Issues | Warranty | Recalls / TSB 70 11-20-2020 09:16 AM
Hood moving at highway speeds Jarrid'sBRZ BRZ First-Gen (2012+) — General Topics 17 06-13-2017 09:11 AM
Average speeds on the highway? Yamajee Scion FR-S / Toyota 86 GT86 General Forum 67 09-29-2013 12:41 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
