Old 06-03-2017, 07:51 PM   #1
Jarrid'sBRZ
Drives: 2016 Black subaru BRZ limited
Hood moving at highway speeds
Hello,
So I was driving on the highways and I noticed that the hood starts to shake where the fenders meet it. Stopped at a gas station to check. The hood was fully latched and all the hood gaps look normal. Has anyone ever seen this happen before?
Jarrid'sBRZ is offline   Reply With Quote
Old 06-03-2017, 08:08 PM   #2
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
I can see my hood push/bend down when I pass through the air/blow dry at the touchless car wash.
The hood is made of aluminium, so I assume it will flex a lot easier as opposed to a steel hood on most cars.
Si_Chris is offline   Reply With Quote
Old 06-03-2017, 08:19 PM   #3
gramicci101
Off Topic
This is pretty common. For me crosswinds really make it flex. It hasn't come off yet though, so you're probably fine.
Old 06-03-2017, 08:22 PM   #4
Somerandom18
Drives: 2017 manual BRZ
Normal.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 06-03-2017, 08:32 PM   #5
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Normal.
Old 06-03-2017, 08:36 PM   #6
Can be adjusted with the latch and bump stops if it really bothers you.
Ultramaroon (06-03-2017), vintagemxer (06-04-2017)
Old 06-03-2017, 09:11 PM   #7
navanodd
Drives: 2013 BRZ Sport-tech WRB
Active aerodynamics.
navanodd is offline   Reply With Quote
The Following 3 Users Say Thank You to navanodd For This Useful Post:
gramicci101 (06-03-2017), Jarrid'sBRZ (06-03-2017), Tcoat (06-03-2017)
Old 06-03-2017, 09:49 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's normal. Like others said it's due to light weight aluminum and the bump stops.
Old 06-03-2017, 10:27 PM   #9
Decep
Drives: 2013 FR-S Series 10
I have only noticed this on shitty gravel roads. You should be able to adjust those rubber bumpers to minimize it.
Old 06-03-2017, 11:02 PM   #10
SlowCarFast
Drives: 2015 BRZ Limited
It was just not adjusted well at the factory.
Take the rubber stoppers on the front corners and rotate them down a quarter to half turn. Should fix it. If it throws your flushness off to your fenders, then put the stoppers back where they were and instead crack the latch bolts loose a hair and barely tap the latch down a mm or 2.
If these do not fix it then it is an inherent problem with the construction and cannot be fixed easily. It is a minor annoyance at worst.
SlowCarFast is offline   Reply With Quote
Old 06-04-2017, 09:19 AM   #11
alan.chalkley
Drives: 4wd zooks
This is only a big problem with superchargers , when it rubs onto the top pulley and creates a very use full air vent through the aluminium.
alan.chalkley is offline   Reply With Quote
Old 06-04-2017, 10:08 AM   #12
Esseff
Drives: 2017 BRZ Ltd White
Wow. After all the research I've done on this car and owning one for the last 4 months, I never realised the bonnet was ally. Very impressed!
Maybe that explains why my buddy thought the bonnet was gas assisted when he lifted it the other day. He's an ex race car builder so I am looking forward to telling him his observation was well founded. I'm sure he will also be impressed.
Esseff is offline   Reply With Quote
Old 06-06-2017, 01:01 PM   #13
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
the engine cat is doing its job
DuMa is offline   Reply With Quote
Old 06-06-2017, 01:36 PM   #14
extrashaky
Drives: 2014 BRZ Limited
Well did you know about this:
The prop for the hood (or bonnet for you subjects of the Queen) comes completely out so that you can mount it in another hole higher up the engine bay to prop the hood almost straight up. Doing that turns the hood prop at a weird angle, but never fear: They put another rectangular hole at an angle in the hood itself, so that it still fits.
The Following User Says Thank You to extrashaky For This Useful Post:
funwheeldrive (06-06-2017)
Car swaying left right (floating feeling) highway speeds FX86 Issues | Warranty | Recalls / TSB 37 05-30-2021 11:48 AM
BRZ not stable at highway speeds unplugged Issues | Warranty | Recalls / TSB 70 11-20-2020 09:16 AM
Average speeds on the highway? Yamajee Scion FR-S / Toyota 86 GT86 General Forum 67 09-29-2013 12:41 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
