Old 04-02-2016, 03:22 PM   #1
unplugged
Master Member
Drives: Subaru BRZ
BRZ not stable at highway speeds
I recently bought a '16 BRZ Limited in early March. Today was one of the first days I really got to drive it more than 20 miles on open highway and not to the dealership.
At 500 miles, my alignment was out, they fixed the rear toe and everything now is in spec. Now at 628 miles, cruising around 70-75mph (yes within speed limits) my car will literally shift left or right and it doesn't matter which lance since I know the road crown can give a slight pull.
Around a slight right bend on the highway, the car literally went half way into another lane.
Had the alignment checked elsewhere, still in spec. I even looked under the car and found nothing out of the ordinary.
Now I know the car is light and it was a bit windy, but I never felt unsafe driving a new car. My C5 vette will handle these slight bends like nothing even in tornado storm weather. Granted it has a much lower COG, wider tires, and beefier suspension.
I'm wondering if this is normal for the BRZ, or if lowering it and having wider tires will help. Or is there something actually wrong with the vehicle.
unplugged is offline   Reply With Quote
Old 04-02-2016, 03:29 PM   #2
ryoma
ryoma's Avatar
what is "within spec" that the alignment people are telling you? do you know the numbers? sounds like you have a problem with the toe to me. I'm assuming your car is stock, and the "stock" alignment has a wide range that can be considered within spec.
Old 04-02-2016, 03:42 PM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Show the alignment print out. Within spec may still have variances. Example the spec can be -.08 and .08 and you can be sitting at both extreme ranges per side.
N1rve
Old 04-02-2016, 03:43 PM   #4
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Been to 127mph and it felt very solid. I suspect misalignment. I would have it checked by a different shop.
justatroll is offline   Reply With Quote
Old 04-02-2016, 04:15 PM   #5
nvus_frs
Stanced Idiot
nvus_frs's Avatar
Drives: 2015 Halo FR-S M/T
makes two of us. even after I slammed my twin running around -5 to -6 camber all the way around it felt stable at 120mph and i was driving without an alignment at the time. Just put the coils lcas and all that and drove around till the next paycheck. never had my car pull to a side unless its windy out
OP sounds like a one off issue or whoever did your alignment missed something.
"M3 drivers have no friends." -Jeremy Clarkson
Build Blog:
https://tiltedjan.wordpress.com/
nvus_frs is offline   Reply With Quote
Old 04-02-2016, 05:55 PM   #6
14 hours a week spent on the highway and it takes curves like it is on rails. There is something not right.
Old 04-02-2016, 06:24 PM   #7
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
^Yup, get the exact specs from them.
rookie is offline   Reply With Quote
Old 04-02-2016, 06:48 PM   #8
gravitylover
I did over 600 miles yesterday from the northern NY 'burbs to within 75 miles of the Canuckistanian border in northern NH and back, interstates and back roads in all sorts of weather at all sorts of speeds and not a problem with stock tires that have ~40,000 miles on them. There is something not right with your car.
ps: ooh I had my best mpg tank ever at 34 with an avg speed a little over 70mph
Old 04-02-2016, 07:35 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
misalignment or defective tires.
Old 04-02-2016, 07:59 PM   #10
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
They screwed something up or something is defective on your car. I routinely cruise at 100mph+ and my BRZ is laser straight and stable. I have wide sticky tires too so I'm putting more load on the steering and suspension.
Hood starts to wiggle, sure, but tracks perfect.
Old 04-02-2016, 08:47 PM   #11
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
I am curious if it was extreme wind (but sounds like you took that into account).
Were there grooves in the pavement? I know on my motorcycles that can make my bike shake.
And the obvious most likely answer...something is just wrong with suspension bits (all the stuff people above me mentioned).
I am not super-mechanic or anything...could it be something wrong with the steering wheel/column and that set up?
Atropine is offline   Reply With Quote
Old 04-02-2016, 09:54 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
http://www.agcoauto.com/content/news/p2_articleid/307
Old 04-03-2016, 03:00 AM   #13
gravitylover
^^ One thing in that article bugs me. It says new tires always go on the rear. I've always done exactly the opposite, if I'm only replacing two they go on the front.
Old 04-03-2016, 03:58 AM   #14
shattered_memory
Drives: Satin White BRZ Limited
Our cars are sensitive to the wind at highway speeds.....well mine is anyway. However, I honestly don't mind it or feel unsafe. I love the feel and handling of this car. I am sorry if you are not satisfied with your purchase.
shattered_memory is offline   Reply With Quote
Stock pads dangerous in cold/wet @ highway speeds? SloS14 Issues | Warranty | Recalls / TSB 14 03-09-2014 03:26 AM
Average speeds on the highway? Yamajee Scion FR-S / Toyota 86 GT86 General Forum 67 09-29-2013 12:41 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
RPM at Highway Speeds sparis45 Scion FR-S / Toyota 86 GT86 General Forum 21 05-26-2013 02:41 PM
