Old 06-03-2021, 01:07 PM   #1
CrazyOkie
CrazyOkie's Avatar
Drives: 2020 Toyota 86 GT "Taka"
oil/grease in the right front wheel well?
2020 86 GT, with TRD springs, sway bar, exhaust.
I have some thick oil, possibly grease dripping onto the garage floor below the right front wheel well. Looking up at it (without jacking the car) I saw what looked to be some dirty oil on the control arm and what appears to be a spray of the same fluid on the wheel well itself.
I wiped it off the control arm and so far haven't seen any more drip down in 2 days, but there's still the stuff on the wheel well (the 86 is not my daily driver).
First thought was I ran through something. Second thought was maybe the CV boot is failing. But the car doesn't even have 2,000 miles on it yet.
Any thoughts? Picture attached of the fluid on the floor of the garage. Tried taking a picture of the wheel well but didn't come out good.
CrazyOkie is offline   Reply With Quote
Old 06-03-2021, 01:08 PM   #2
jflogerzi
jflogerzi's Avatar
leaking damper?
2013 Series 10 FRS #553
Old 06-03-2021, 01:30 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well it's not going to be a CV since there isn't one in the front of a RWD car.
I would get that side of the car and pull the wheel off and have a peak around. Bet it is engine oil though, probably escaping from somewhere off the timing cover and running down the skid plate.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (06-03-2021), strat61caster (06-03-2021)
Old 06-03-2021, 04:39 PM   #4
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
If its only 2k miles and a 2020, bring it back to the dealer for them to take care of under warranty.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Axle Leaking Grease 636 Engine, Exhaust, Transmission 14 07-20-2017 09:09 PM
Wheel bearings sealed? Grease? swarb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-10-2016 11:08 AM
Grease gun tips? ZionsWrath Other Vehicles & General Automotive Discussions 3 12-07-2015 09:29 AM
True to add grease to the wheel lock nuts or not necessary? dssence Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-05-2014 01:27 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 09:49 PM
