Old 03-02-2015, 07:45 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Axle Leaking Grease
So I was getting an alignment today, after running -11.5 degrees of camber, I'm not not surprised that my axle is starting to leak.
I'm back down to -3 degrees, and there's no noise yet, but there is axle grease coming from the driver side boot. Do they make replavement boot kits for our cars? Or am I just gonna bike the bullet and buy some DSS axles?
636 is offline   Reply With Quote
Old 03-04-2015, 11:21 AM   #2
636
636's Avatar
Drives: '23 CWP BRZ
Bump
Old 03-04-2015, 11:24 AM   #3
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Coincidentally just had a buddy and fellow forum member @raul replaced his for the same motive under warranty at about 55k. His car isn't running that much camber that I'm aware of though so taking it may not work out.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
raul (03-04-2015)
Old 03-04-2015, 11:34 AM   #4
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Running -2.5 in the rear.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
yomny (03-04-2015)
Old 03-04-2015, 11:47 AM   #5
yomny
yomny's Avatar
So they leak lol, looking forward to this lol as im at -2.6-2.7 rear.
Old 03-04-2015, 11:48 AM   #6
raul
Lap time enthusiast
raul's Avatar
I think in my case it has more to do with autocross launching than anything.
Old 03-04-2015, 11:50 AM   #7
yomny
yomny's Avatar
And the OP could be the extreme camber situation. There's never a dull when you modify your car lol.
Old 03-04-2015, 12:40 PM   #8
fika84
fika84's Avatar
Items 3 & 4 - https://www.subarupartsdepot.com/par...agramCallOut=1
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
yomny (03-04-2015)
Old 03-04-2015, 12:43 PM   #9
yomny
yomny's Avatar
So the boots? At least they're not too expensive.
Old 03-04-2015, 01:59 PM   #10
fika84
fika84's Avatar
That should be all you need as long as you don't hear clicking.. typically if you get the boots replaced and everything greased quickly after they start leaking you can avoid having to change the actual joints! Once you get dirt in the joints and start hearing clicking when turning then you will need to change the joints as well..
Old 03-04-2015, 04:24 PM   #11
stevesnj
stevesnj's Avatar
If your boots are leaking I'd find the source. If the CV's are loosing grease thats a problem. If you can get some grease in there I would think about tht..a pic with the boot off would be interesting to see too. :]
My 2016 Build thread
Old 03-04-2015, 08:28 PM   #12
636
636's Avatar
Drives: '23 CWP BRZ
Thanks guys! No clicking noise yet. I'm down to -3.5 degrees of camber, but will be dropping to -2 degrees after I replace the boots.
I'm 100% positive the leaking is due to my -11.5 degrees, as well as drifting and launching on that much camber.
Old 03-04-2015, 09:08 PM   #13
stevesnj
stevesnj's Avatar
Yeh that'll do it..lol And did you say front? There's no CV's on the front just tie rod ends connected to the steering rack. If a tie rod end is leaking you should replace it right away. You don't want to have one break on you. With that camber with drifting is not a good combo for the stock tie rods. I'd get extra heavy duty if you continue to drift
Old 03-05-2015, 11:45 AM   #14
636
636's Avatar
Drives: '23 CWP BRZ
Nah, no problems up front, only the driver side rear.
The Following User Says Thank You to 636 For This Useful Post:
stevesnj (03-05-2015)
True to add grease to the wheel lock nuts or not necessary? dssence Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-05-2014 12:27 AM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 08:49 PM
CMS SEMA 2013 coverage - Whiteline anounces new black Grease-less bushings Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-11-2013 04:19 PM
Interior window film (grease?) Cjymiller Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 06-06-2013 08:23 AM
Sharp grease lines Tiremonkey0824 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 09-24-2012 01:29 PM
