Old 02-02-2014, 08:02 PM   #1
dssence
Drives: Toyota FT/MT 86
True to add grease to the wheel lock nuts or not necessary?
Well guys just wanted to know if it's necessary to add any grease or lube to the wheel lock nuts or that would make the nut stick even more and be hard to remove later.. i've heard some ppl use some grease. No idea.
dssence is offline   Reply With Quote
Old 02-02-2014, 08:10 PM   #2
kodyo
Drives: Scion FR-S
Manual says not to use grease, so I did not. If you grease up the lugs and torque to the recommended torque spec, you will have a higher preload value than if you had left the studs dry. Whether that is good or bad for a car hub, i don't know. It's either a preload issue, or they are worried about vibrations loosening the lugs when greased.
kodyo is offline   Reply With Quote
Old 02-02-2014, 08:25 PM   #3
humfrz
Well, dssence, I've been putting wheels on vehicles for over 60 years and never lubricated a lug nut stud. I've never had a nut that I couldn't get off, nor have I ever had a lug nut come lose or lost a wheel.....
PS - I just tighten them down with a "star" pattern and tighten them up with a "cross" wrench till they squeak twice or I grunt once. Some folks use a torque wrench (around 75 ft lbs of torque usually keeps them on).
amram (02-05-2014), dssence (02-02-2014)
Old 02-02-2014, 08:28 PM   #4
dssence
hehe well that's nice you haven't lost a wheel .. Listen which wheel lock nuts you recommend , Mc gard ones? . I live in argentina they said to me the wheel lock nuts for the FRS are the same as for the corolla M12 x 1.5 is that correct?
Old 02-02-2014, 08:28 PM   #5
Tiremonkey0824
Drives: 2013 Argento 6mt
If you grease the lug or stud you could very easily over torque the bolt trying to get it to spec. It will just keep spinning and the torque wrench may not click.
Tiremonkey0824 is offline   Reply With Quote
Old 02-02-2014, 08:38 PM   #6
kodyo
Drives: Scion FR-S
I have mcgards. Thread is M12x1.25.
Old 02-02-2014, 08:42 PM   #7
dssence
Damn how can I check if mine is M12 x 1.5 , heard people saying the corolla fits this one . I own a toyota 86 FT . should I use a caliper?
Old 02-02-2014, 09:01 PM   #8
kodyo
Drives: Scion FR-S
Sure, you could use caliipers. Measure 10 threads from peak to peak or valley to valley and if it's 12.5mm, then you know the pitch.
I'm almost 100% sure it's going to be 1.25 regardless of the country. I bought the Mcard M12X1.25 and it fits the FRS. Could do a quick google search as well.
Old 02-04-2014, 11:41 PM   #9
Selvedge
It's supposed to be 89 ft lb of torque.
Selvedge is offline   Reply With Quote
Old 02-05-2014, 12:27 AM   #10
humfrz
Good information, there Selvedge ......
I reckon my two squeaks and a grunt have weakened over the years .....
**BEST Lug Nuts with Lock*** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 05-25-2014 04:22 PM
Are our wheel bearings and bushings sealed or are we able to grease them up ? ScionFR-S Issues | Warranty | Recalls / TSB 4 01-28-2014 08:49 PM
BRZ stock lugs and lock nuts w/ key scion dad Wheels and Tires 0 09-15-2013 09:46 PM
Lug Lock nuts - confused with type etc tech86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 07-15-2013 01:03 AM
RAYS RACING DURA NUTS EXTENDED 50MM RED WITH LOCK 20 PCS 12X1.25MM ???? 20valvewynn83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-07-2013 04:33 PM
