Wheel bearings sealed? Grease?
Are our wheel bearings sealed? If not, what type of grease do they use? Repack with another type?
#2 | |
Drives: '23 BRZ Limited
2. Whatever cheap junk they can find. And usually lightly packed. 3. I would, especially if using for Auto-X/Track. Even though front hubs don't seem to be an issue on these cars, on NA/NB Miatas it was a huge problem. To the point that there 4+ vendors offering upgraded hubs. Some were just stock hubs that had been repacked with high quality grease (withstand high temps better). Some were rebuilt with higher quality grease and ARP studs. The most high end ones went so far as to change out the ball bearings for one closer in tolerance (more even loading on all the bearings), plus high quality grease and ARP studs. I wish there were some options like this for us, I hate doing jobs like that. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | swarb (06-10-2016) |
Typically front bearings are quite durable and aftermarket are the junk ones. I had an original front bearings last 200k miles in a car.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | swarb (06-10-2016) |
| [HELP] Rear Wheel Bearings | VITA | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 10-14-2019 01:58 AM |
| Oem rear wheel bearings+oem inner tie rods | Integramike94 | Brakes, Suspension, Chassis | 7 | 09-25-2016 05:48 PM |
| Grease gun tips? | ZionsWrath | Other Vehicles & General Automotive Discussions | 3 | 12-07-2015 08:29 AM |
| True to add grease to the wheel lock nuts or not necessary? | dssence | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-05-2014 12:27 AM |
| Are our wheel bearings and bushings sealed or are we able to grease them up ? | ScionFR-S | Issues | Warranty | Recalls / TSB | 4 | 01-28-2014 08:49 PM |
