| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Thanks
Grease gun tips?
Trying to lube some zerk fittings on endlinks I replaced.
Can't seem to get this grease gun to work. I tightened the connections and I can pump endlessly and nothing seems to happen then some grease starts to ooze from the gun/zerk connection. I removed the zerk fitting and see a tiny amount of grease inside the ball joint of the end link. But the boot isn't even starting to bulge so I know there isn't much getting in there. How can I do this properly.
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
The check ball in the zerk fitting may be stuck. Did any of them work?
| The Following User Says Thank You to BirdTRD For This Useful Post: | ZionsWrath (12-07-2015) |
not playing cards
Do you feel any resistance in the handle/trigger? Try pumping some grease into a paper towel. My shitty old grease gun can't manage even the tiniest little air bubble.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ZionsWrath (12-07-2015) |
Thanks
Checked everything. Zerk fittings were fine. disassemble reassemble grease gun.
Decided it was defective, bought a new one. New one works no problems. Not sure what was wrong, maybe it was a piece of garbage. It was hardly putting out any grease no matter what I did. Thanks for input.
| The Following 2 Users Say Thank You to ZionsWrath For This Useful Post: | Tcoat (12-07-2015), Ultramaroon (12-07-2015) |
| Axle Leaking Grease | 636 | Engine, Exhaust, Transmission | 14 | 07-20-2017 08:09 PM |
| True to add grease to the wheel lock nuts or not necessary? | dssence | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 02-05-2014 12:27 AM |
| Are our wheel bearings and bushings sealed or are we able to grease them up ? | ScionFR-S | Issues | Warranty | Recalls / TSB | 4 | 01-28-2014 08:49 PM |
| Interior window film (grease?) | Cjymiller | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 06-06-2013 08:23 AM |
| Sharp grease lines | Tiremonkey0824 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 09-24-2012 01:29 PM |
