Old 03-15-2021, 11:34 AM   #15
paintdude258
paintdude258's Avatar
Originally Posted by Dzmitry View Post
Does your new oil have a different viscosity than the last?
It did not. Same oil. I am using xl 5w-30 synthetic for boosted vehicles from Amsoil.
paintdude258 is offline   Reply With Quote
Old 03-15-2021, 11:57 AM   #16
jflogerzi
jflogerzi's Avatar
Originally Posted by paintdude258 View Post
Intercooler did not get cleaned. Would it/does it need it?
I am not an expert but I think it's recommend after a blown engine. I think some residue can get into it. But might want to do some research
2013 Series 10 FRS #553
Old 03-15-2021, 11:58 AM   #17
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I see. In any case, as stated earlier, white smoke typically refers to coolant burning off. The hazy mixture you speak of also seems to point in that direction - head gasket failure.
EDIT: So how about the coolant then. Any loss there?
Dzmitry is offline   Reply With Quote
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
DarkSunrise (03-15-2021), Wally86 (03-15-2021)
Old 03-15-2021, 02:39 PM   #18
tomm.brz
Drives: brz 2017 hksv2
I don't understand your question.
Sorry
wanted to write
you should take a log
paintdude258 (03-23-2021)
Old 03-15-2021, 07:04 PM   #19
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Marble cake oil is an indicator of water getting into the oil. Another vote for head gasket. That said, chocolate swirl oil is a lot better that metal flake.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Old 03-15-2021, 09:25 PM   #20
Grady
Grady's Avatar
If the engine just blew then intercooler should be good, If when the engine blew the turbo compressor failed then the parts of the compressor would contaminate the intercooler. What exactly failed on your engine?
The Following User Says Thank You to Grady For This Useful Post:
Old 03-23-2021, 04:34 PM   #21
paintdude258
When I first started running the car after installing the new motor, I was loosing coolant. Turns out, there were three hoses that were either missing clamps or the clamps were not tightened down enough, causing coolant drips. The aftermarket radiator cap I had was also not sealing correctly, allowing coolant to bypass it. I havent run the car much since addressing these leaks, so I am honestly not sure if the coolant level is still dropping.
Old 03-23-2021, 04:37 PM   #22
paintdude258
Spun a bearing. Turbo was sent off to Precision to get refreshed. They found no major issues with the turbo, so they replaced all the replaceables and sent it back.
Old 03-24-2021, 08:51 AM   #23
Dzmitry
Dzmitry's Avatar
I would look into that. Because either oil or coolant disappearing would be huge indications of what is likely the case.
Old 03-26-2021, 03:54 PM   #24
paintdude258
**UPDATE**
Took my car to an engine shop and they believe that under boost pressure, I am floating the heads, causing coolant to enter the combustion chamber, leading to the white smoke.
They are going to upgrade the head gasket and install ARP head studs.
The verdict seems logical. Anyone else have experience with such an occurrence?
The Following 2 Users Say Thank You to paintdude258 For This Useful Post:
Dzmitry (03-29-2021), Wally86 (03-29-2021)
Old 03-26-2021, 04:22 PM   #25
Capt Spaulding
Persona Non Grata
Not personally, but you're not the first to report receiving that diagnosis.
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
paintdude258 (03-31-2021), Wally86 (03-29-2021)
Old 03-31-2021, 04:24 PM   #26
paintdude258
Thats good to know. I did a search, but didnt find anything that talked about such an occurrence.
Burning smell and white smoke Tacticalpanda Issues | Warranty | Recalls / TSB 22 09-04-2024 09:18 AM
Frs 2016 white smoke/burning smell uhnexo Scion FR-S / Toyota 86 GT86 General Forum 14 09-04-2024 09:17 AM
White smoke, burning smell, puddle of brown fluid leaking. driftking96 Engine, Exhaust, Transmission 5 02-20-2016 02:54 AM
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 05:23 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 10:57 AM
