Old 10-01-2013, 12:01 AM   #1
hansthegerman
Drives: Scion FRS
White smoke coming from the exhaust.
Hi all. I've noticed recently that on occasion I get some white smoke coming from the exhaust. It looks a lot like cold start smoke, except it happens when it isn't exactly cold. For example, got it tonight driving from my buddies when it's 56 degrees outside. I also got it driving back from Massachusetts the other day... 3 hours into my drive while sitting in traffic. It wasn't particularly cold then either, about 55-65 degrees. This doesn't seem normal, any ideas or am I just being paranoid?
hansthegerman is offline   Reply With Quote
Old 10-01-2013, 12:50 AM   #2
KONVERTER
KONVERTER's Avatar
how many miles on it?
KONVERTER is offline   Reply With Quote
Old 10-01-2013, 08:20 AM   #3
hansthegerman
Drives: Scion FRS
Old 10-01-2013, 09:53 AM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
sure its not condensation? Correct me if I'm wrong but at least in my experiences white smoke was oil being burned/head gasket.
Old 10-01-2013, 09:56 AM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
White smoke is burning coolant, blue smoke is burning oil.
Old 10-01-2013, 10:24 AM   #6
stugray
Drives: 2013 GBS BRZ Limited
I was going to suggest a blown head gasket.
Check your oil for any signs of coolant & get it to the dealer ASAP.
Blown head gaskets can ruin a lot of other engine componenets.
Even if you fix the gasket issue, you might do harm to other parts of the engine.
Old 10-01-2013, 10:29 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes.
Old 10-01-2013, 10:52 AM   #8
stugray
NO! have it checked. I have NEVER seen my car blow ANY smoke Black, blue, white, or otherwise.
Old 10-01-2013, 11:09 AM   #9
hansthegerman
Drives: Scion FRS
Just flushed the oil yesterday. Oil was dark, definitely not milky. At the stealership now. I had oil leaking somewhere. Skid plate was covered in oil. Well see what they say...
Edit. First time I saw the smoke was after driving for 3 hours from Massachusetts while sitting in traffic on the hutchinson. Thats why I was alarmed. Didnt think I should be blowing smoke after driv8ng it for 3 hours. It was around 9pm abd oat was about 65 degrees.
Old 10-01-2013, 11:45 AM   #10
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
If there is an oil leak and it is burning on the exhaust I'm pretty sure it would produce a white smoke trail out the back(underneath). Also I read that if you have a manual there is a plate on the block that sometimes leaks(covered since we dont have an Auto).
lickitysplit is offline   Reply With Quote
Old 10-01-2013, 01:58 PM   #11
hansthegerman
Drives: Scion FRS
So i just got back from the dealer. Said the oil leak was the crush washer which I find hard to believe since I just changed my oil and replaced the crush washer yesterday, and it did leak before I replaced the crush washer too. Didn't really comment on the smoke, said it depends on the conditions the car is in and it is possible that it is normal. They said I have the 5 year 60 thousand mile warranty so if anything does happen, it'll be covered by that. I'm kind of worried that nothing got fixed but at least now I've got some paperwork from the dealership so if things do go awry, I'll at least I have paperwork regarding the issue...
Old 10-01-2013, 04:58 PM   #12
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
It's always ideal to check at a stealership when things are under warranty. You're covered in the event something happens.
How were you driving when this happened? Sometimes small exhaust events can occur when the ECU is changing fuel trims, etc.
I blew my head gasket on my car....let me tell you, it's not just a puff of smoke, its:
coming out of your exhaust
Jason@DSG is offline   Reply With Quote
Old 10-01-2013, 08:04 PM   #13
hansthegerman
Drives: Scion FRS
I was sitting in traffic idling. But. It went from doing 70-80 on the highway, to a dead stop. only a few minutes after stopping i saw the smoke. I saw it for a good 10-15 seconds and then it went away. Saw the same thing last night driving from my buddies house, but in fairness. His house is around the corner, car could have not warmed up yet.
This was definitely not something extremely alarming. It literally looked exactly like the smoke you get on a cold morning. Same density and everything. The conditions the car was in just didn't seem right for the smoke to appear to me. That's why I was concerned.
Old 10-01-2013, 08:22 PM   #14
lickitysplit
Don't care
Figured as much, oil was dripping on hot stuff and burning.
Cloud of white smoke on startup wawro569 Issues | Warranty | Recalls / TSB 25 01-16-2015 12:55 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 02:59 AM
Smoke from new USA TRD exhaust DaveFTW Engine, Exhaust, Transmission 22 10-03-2012 04:03 PM
