Old 10-03-2019, 08:28 PM   #1
uhnexo
Drives: scion fr-s
Frs 2016 white smoke/burning smell
i changed my cam plate but it still has a smell and it smokes a lot more?
uhnexo is offline   Reply With Quote
Old 10-03-2019, 08:45 PM   #2
Decep
Drives: 2013 FR-S Series 10
you need to be more specific.
i put in about as much effort into my reply as you did your post.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
Busybee (10-03-2019), Grady (10-03-2019)
Old 10-03-2019, 11:04 PM   #3
Grady
Grady's Avatar
White smoke=coolant
Blue smoke=oil
Black smoke=Fuel
as stated above more info needed!!!!!!!!!!!!!!!!!!
Old 10-04-2019, 01:55 AM   #4
humfrz
Welcome to the forum, uhnexo -
Are you sure it was the old cam plate that was leaking?
Did you replace it with an aftermarket plate?
Did you follow the installation instructions carefully?
Did you lightly oil the "O" ring before bolting on the plate?
Did you use some sort of sealant?
Did you clean up all the old leaked oil off the exhaust pieces?
Talk to us.
humfrz
Old 10-04-2019, 01:58 AM   #5
uhnexo
Drives: scion fr-s
Did you lightly oil the "O" ring before bolting it on?
Talk to us.
humfrz
yes i cleaned everything and no oil is coming down anymore but there is still white smoke coming out and the smell
The Following User Says Thank You to uhnexo For This Useful Post:
humfrz (10-04-2019)
Old 10-04-2019, 01:59 AM   #6
uhnexo
Drives: scion fr-s
Originally Posted by Grady View Post
White smoke=coolant
Blue smoke=oil
Black smoke=Fuel
how would i fix the coolant problem because i seen that my coolant is also very low
Old 10-04-2019, 02:03 AM   #7
humfrz
White smoke coming out from where?
What does the "smoke" smell like?
humfrz
Old 10-04-2019, 02:17 AM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That's funny, I thought only the BRZs had the built-in vape...
The Following 4 Users Say Thank You to Spuds For This Useful Post:
ElijahF (10-05-2019), JesseG (10-06-2019), Mr.ac (10-05-2019), Tcoat (10-04-2019)
Old 10-04-2019, 11:35 AM   #9
Grady
Grady's Avatar
Figure out where the coolant is getting into the combustion chamber and fix it. I do not know all the areas where this can happen on a FA20 but most likely culprit on most engines is the head gasket.
Old 10-04-2019, 11:45 AM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Why not bring it into a shop to have them pressure test your cooling system? This will tell you if there's a leak externally or internally.
I see you're in Vegas, but it is worth mentioning that the nights are getting cooler. What have the temperatures been when you're seeing this? Could be normal operation steam if you're seeing temps at or below 50f.
Old 10-04-2019, 11:41 PM   #11
uhnexo
Drives: scion fr-s
humfrz
i noticed that when i filled up my washer fluid it completely ran out and the smoke is under the engine near the cam plate
humfrz (10-05-2019)
Old 10-05-2019, 12:06 AM   #12
humfrz
I suggest you take your car into an automotive shop and ask them to fix it.
humfrz
Old 10-08-2019, 01:47 PM   #13
Riftur
Riftur's Avatar
Check your oil and see if it looks milky. If it does, coolant is getting in there. Like the guy above stated, head gasket.
Riftur is offline   Reply With Quote
Old 10-08-2019, 02:07 PM   #14
Washer fluid? Completely ran out? The "smoke" isn't steam from a leaky washer fluid canister? Seems pretty straightforward doesn't it?
Burning smell and white smoke Tacticalpanda Issues | Warranty | Recalls / TSB 22 09-04-2024 09:18 AM
'17 BRZ burning smell Zoh Issues | Warranty | Recalls / TSB 28 05-15-2017 12:09 AM
Burning smell Riftur Engine, Exhaust, Transmission 9 04-13-2016 02:50 AM
White smoke, burning smell, puddle of brown fluid leaking. driftking96 Engine, Exhaust, Transmission 5 02-20-2016 02:54 AM
Smoke and burning rubber smell JayDee Other Vehicles & General Automotive Discussions 7 03-15-2014 11:25 PM
