Old 02-19-2016, 08:19 PM   #1
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
Exclamation White smoke, burning smell, puddle of brown fluid leaking.
Earlier in a previous post, I couldn't get my engine to run as it would crank and stall right after. Now I am able to get the engine to run, but I have to keep using the throttle to maintain high RPMs to have it running as it won't idle on its own. I tried running my OBD using Torque Pro and I got a misfire detected and 2 historic faults (pictures attached) along with vehicle test results.
After I ran my CEL test, I noticed a burning smell and white smoke coming from the engine. I immediately shut it off and investigated and I heard a knocking sound inside the engine and (oilpan?)pan below it. I don't have a radiator or coolant as the pipes, and actual stuff is broken from the accident. I only ran the car for few mins but I feel like I may have overheated it by trying to maintain engine using throttle. I have uploaded video of the smoke and knocking sound. Also when I checked underneath I found a puddle of brown fluid (engine oil?) on the ground and it was leaking from the passenger side underneath the car close to the front (uploaded pics and video for that too). Any idea what I did wrong and what is wrong and how I could go about diagnosing the problem and fixing it? Please don't be a **** and say negative things here, I'm doing this out of my love and passion to fix and learn about my FR-S and I need some guidance. Thanks in advance.
FYI: Working on a rebuild/trying to fix car after accident.
Video of smoke and knocking sound after engine was shut off: https://vid.me/wFYb
Video of oil leak/puddle: https://vid.me/6Ptd
Pictures of oil leak, CEL codes, Vehichle test results from OBDII and Torque Pro: http://imgur.com/a/WwIrD
driftking96 is offline   Reply With Quote
Old 02-19-2016, 10:06 PM   #2
steve99
It virtually impossible to diagnose accident damge via pictures and obd codes.
Dont run engine without coolant.
It looks like you have an engine oil leak could be anywhere or annyting even cracked block. pullit apart and find the leak. The smoke is likely oil dripping onto hot exhaust. The sound in video is metal expanding or contracting likely exhaust and is normal whwn cooling down.
If you getting knocking noises when engine running thats bad.
Im not being mean here but i suggest you get a qualified mechanic to inspect you car before you start it again . The obd codes only indicate electrical ecu or sensor problems and it appears you have a throttle actuator or position sensor problem.
But these codes do not indicate or show mechanical problems they just show the effects.
Get someone to look at it else you will likely cause further damage
Old 02-19-2016, 10:10 PM   #3
driftking96
Okay thanks for the advise and the info man, I'll ask a few of my mechanic friends and see if they can take a look at it for me.
Old 02-20-2016, 12:53 AM   #4
humfrz
Im not being mean here but i suggest you get a qualified mechanic to inspect you car before you start it again . .............
I totally agree with steve99.
@driftking96 ...... I can appreciate your wanting to fix your car yourself and learn while you are doing it.
That's how we learn. HOWEVER, there usually comes a time on a learning curve, that one needs to admit they need some "hands on" help.
I feel you need more time looking over a mechanics shoulder ......
humfrz
Old 02-20-2016, 01:11 AM   #5
ryoma
ryoma's Avatar
trial and error is usually how you learn and if you don't want to spend some big $$ repairing your mistakes, take it to a qualified mechanic and not a backyard mechanic. and especially don't run your engine for a few minutes and revving it up high with no coolant... come on... lol.
Old 02-20-2016, 01:54 AM   #6
Theratt1
Theratt1's Avatar
Drives: Blown engine
Seems like it overheated and split the block halves. Thats my guess. And if it's knocking. Well Cross your fingers but you probably need a new engine.
Theratt1 is offline   Reply With Quote
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 01:11 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
burning smell when in reverse fito68 Southern California 8 12-30-2014 06:21 PM
Smoke and burning rubber smell JayDee Other Vehicles & General Automotive Discussions 7 03-15-2014 10:25 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
