Old 02-12-2021, 01:45 PM   #15
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
7k: https://www.motor1.com/news/487296/h...r5g7Qy-nydjoOw
I dont know if any RWD trannies that can fit these except maybe some BMW 5 speed getrags?
DuMa is offline   Reply With Quote
Old 02-12-2021, 02:19 PM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Guys make their own adaptors all the time. Not really much of an obstacle.
Old 02-12-2021, 02:41 PM   #17
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Honda has a support team that works with those that are doing swaps so there’s factory backup so there shouldn’t be any disasters
TommyW is offline   Reply With Quote
Old 02-12-2021, 02:56 PM   #18
Icecreamtruk
Drives: Track preped NA FRS
Factory backup doesnt mean free backup. If money isnt an issue, you wouldnt be swapping a k engine in, you'd be swapping something much more interesting.
Icecreamtruk is offline   Reply With Quote
Old 02-12-2021, 04:00 PM   #19
TommyW
TommyW's Avatar
Free AFAIK
Old 02-12-2021, 04:19 PM   #20
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Done before, so it's def doable
Irace86.2.0 (02-19-2021)
Old 02-12-2021, 06:08 PM   #21
Ashikabi
Ashikabi's Avatar
Someone would just make an adapter to get a S2k motor to mate to it.
Sent from my ONEPLUS A5010 using Tapatalk
Old 02-15-2021, 10:05 PM   #22
wparsons
wparsons's Avatar
Originally Posted by TommyW View Post
Probably around 15K when all the smoke clears. Guys spend close to that or more I'd imagine on some FA20 builds.
The Pure Automotive K24 swap kit is like $18k in parts alone, using a ~$1000 k24. The K Power kit is looking like it'll be more like $10k (uses a Haltech instead of Motec, and keeps the stock gearbox).
To get this engine in, you're looking at easily more than $20k total with a gearbox that'll actually hold the power, I'd say closer to $25k.
A K24 is a better flowing engine than the CTR engine, and can arguably hold just as much power (boosted obviously) without needing to be built stronger.
The CTR engine only has VTEC on one cam (forget which one), and the exhaust manifold is part of the head which limits mounting options.
For a track car I can see this swap happening. For a street car, forget it, not a chance you're going to get canbus fonctionning for cheap (or at all) so it'll be a hacked job with the engine running and the rest of the car electronics worked on miracles and facebook likes. For a track toy, I can see this as an interesting option to an LS swap. Also, the 305hp number is on the type R civic, which has catalytic converters and is factory tuned with emissions and fuel usage as a concern. In a full free flowing exhaust with an agressive tunning, this will probably be closer to 350 or so, putting it into v8 power territory.
Even in the CTR it makes way more than 305 crank hp, it's more like 290-300 whp. Swapping this and being fully functional won't be any harder than an LS, K series, etc. Any ecu that can run those will easily run this too.
flickr
Old 02-15-2021, 10:33 PM   #23
Ashikabi
Ashikabi's Avatar
The stock computer can technically run it. Forgot who it was but someone on the forum here had a K running off the Subaru computer. They are obviously very good at what they do though and it's not plausible to believe just anyone could do it. But it's been proven
Old 02-19-2021, 11:10 AM   #24
wparsons
wparsons's Avatar
IIRC it has VTEC disabled to do that though, and a bunch of custom work.
flickr
Old 02-19-2021, 11:25 AM   #25
Ashikabi
Ashikabi's Avatar
Vtec isn't that big of a loss. Lots of custom work for sure. But it's possible
Old 02-19-2021, 03:56 PM   #26
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It was solidsnake11. He deleted his posts, but it didn't have a step-by-step/DIY writeup or anything. I think he adapted the stock harness into the Honda's actuators. KPower notes that there will be a stock ECU option instead of using the Haltech ECU. I don't know if it will be cheaper to use the the stock ECU and then using ECUTEK like solidsnake11 did than just using the Haltech system. We will see.
Old 02-19-2021, 05:38 PM   #27
Ashikabi
Ashikabi's Avatar
Haltech is fuckin expensive so I don't see how it couldn't be cheaper. All current swap options that reuse the stock computer are cheaper than the fancy standalones. Only option that might be cheaper is the Hydra EMS from Element Tuning. It could be made to run a Honda motor but I certainly don't have the knowledge to do it
Old 02-19-2021, 05:40 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't think Haltech is that bad. Motec is far more pricey.
wparsons (02-23-2021)
EV West Electric Crate Motor, Thoughts? FunnyGopher Engine Swaps 73 09-14-2023 02:26 PM
DSport Crate Shortblocks Williampreza Engine, Exhaust, Transmission 16 05-21-2018 12:45 PM
PRS, Epiphone, KRK, Crate, Meinl Music Gear! JEFFY_RA86 Miscellaneous 0 01-10-2015 01:55 AM
Watched a Civic blow a motor on the freeway NWFRS Other Vehicles & General Automotive Discussions 29 12-13-2013 11:39 AM
