Old 02-11-2021, 10:16 AM   #1
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Civic R crate motor
Hmmmmm
https://www.hagerty.com/media/news/v...wCWhMxvb-wsNF4
Old 02-11-2021, 11:15 AM   #2
whataboutbob
AutoX-10/10ths every run
https://www.enginebuildermag.com/201...-k20c1-engine/
"...The K20C1 is a direct injected, turbocharged, 2.0L engine that produces 306 hp and 295 lb.-ft. of torque from the factory..."
Build thread:Here
Old 02-11-2021, 11:57 AM   #3
TommyW
TommyW's Avatar
With Honda Reliability
Old 02-11-2021, 12:30 PM   #4
Ashikabi
Ashikabi's Avatar
But is it cheaper thank a turbo K24?
Old 02-11-2021, 12:32 PM   #5
jflogerzi
jflogerzi's Avatar
Limited run of 200 I think and its like 8K....
2013 Series 10 FRS #553
Old 02-11-2021, 12:49 PM   #6
TommyW
TommyW's Avatar
9 out the door ready to go
Old 02-11-2021, 12:50 PM   #7
Ashikabi
Ashikabi's Avatar
Doesn't sound all that attractive
Old 02-11-2021, 01:29 PM   #8
TommyW
TommyW's Avatar
The K24 when built right is pretty damn tough to beat for sure.
Old 02-11-2021, 03:29 PM   #9
DarkSideFRS
Drives: 2013 pearl white FR-S
yup
some ppl who had issues after performing the valve spring recall spent over $10k to get a replacement fa20... i think $8k is a steal for a legendary motor
DarkSideFRS is offline   Reply With Quote
Old 02-11-2021, 03:50 PM   #10
TommyW
TommyW's Avatar
Originally Posted by DarkSideFRS View Post
yup
That was me. I went with a bulletproof IAG shortblock and spent 11K turn key.
I toyed with the idea of going for something with more power or even throwing a turbo on however as far as reliability going much over stock power then you're dealing with a car that just isn't engineered for it for track duty.
Old 02-12-2021, 06:34 AM   #11
yup
The people that paid over $10 included all the labour to remove and replace the engine.
To do this swap you are looking at $9K just for the engine. There will still be all the costs invo;ved in a swap. Even doing it yourself you would be lucky to come in under $12K. If you had to pay somebody well...
Old 02-12-2021, 11:41 AM   #12
Icecreamtruk
Drives: Track preped NA FRS
For a track car I can see this swap happening. For a street car, forget it, not a chance you're going to get canbus fonctionning for cheap (or at all) so it'll be a hacked job with the engine running and the rest of the car electronics worked on miracles and facebook likes. For a track toy, I can see this as an interesting option to an LS swap. Also, the 305hp number is on the type R civic, which has catalytic converters and is factory tuned with emissions and fuel usage as a concern. In a full free flowing exhaust with an agressive tunning, this will probably be closer to 350 or so, putting it into v8 power territory.
Old 02-12-2021, 12:45 PM   #13
TommyW
TommyW's Avatar
Probably around 15K when all the smoke clears. Guys spend close to that or more I'd imagine on some FA20 builds.
Old 02-12-2021, 12:56 PM   #14
Ashikabi
Ashikabi's Avatar
You can get full CAN functionality. But it won't be cheap. Probably looking at spending a little more than current K swaps. There are a couple suppliers now for K swap kits I believe
EV West Electric Crate Motor, Thoughts? FunnyGopher Engine Swaps 73 09-14-2023 02:26 PM
DSport Crate Shortblocks Williampreza Engine, Exhaust, Transmission 16 05-21-2018 12:45 PM
PRS, Epiphone, KRK, Crate, Meinl Music Gear! JEFFY_RA86 Miscellaneous 0 01-10-2015 01:55 AM
Watched a Civic blow a motor on the freeway NWFRS Other Vehicles & General Automotive Discussions 29 12-13-2013 11:39 AM
