Old 02-05-2021, 01:34 PM   #29
DarkSunrise
DarkSunrise's Avatar
Originally Posted by bfrank1972 View Post
Yeah that's a good point - cumulatively it'll make a significant difference, just not so much with the butt dyno In the end it wasn't worth it because I live in CT, I think there are maybe 2 or 3 E85 stations in the WHOLE STATE. One happens to be 'close' in Greenwich, but that's still 1/2 hour drive for me :/
I'm lucky that I've got an e85 station 2 min from me. If my closest was 30 min away though I'd definitely pass on it haha.
2022 BRZ Build
2013 FR-S Build
Old 02-05-2021, 01:35 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You have got to remember there is a pretty significant difference in pump E85 blends, they can run anywhere from 51%-85% ethanol. Here is a chart I found and saved a link to a while back on the octane ratings of different blends. The more octane you run, the more timing you can run(albeit with diminishing returns on the upper end). This is why flex fuel and a proper tune can make a big difference. An OTS E85 tune is going to be pretty significantly compromised to stay on the safe side.
https://www.n54tech.com/forums/showthread.php?t=22328
gen3v8 (02-05-2021)
Old 02-05-2021, 03:36 PM   #31
Lantanafrs2
Drives: 2013 frs red
Check out Lincoln logs video on e85 dyno results
Lantanafrs2 is offline   Reply With Quote
Old 02-05-2021, 05:16 PM   #32
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
This makes total sense
Old 02-05-2021, 05:23 PM   #33
Purist
Purist's Avatar
Drives: Subaru BRZ
Meanwhile in Australia...
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
JesseG (02-05-2021)
Old 02-05-2021, 05:51 PM   #34
bfrank1972
Drives: 2013 FR-S Argento
Agree - I remember Shiv saying that something like E60 or E65 is all you need to fully optimize timing advance on our cars (i.e. knock resistance), but I believe the tunes are optimized for otherwise stock cars. I had a P&L 4-1 header which *did* actually make a noticable seat-of-the-pants difference on 93, so maybe it's a case if you go from stock/pump to stock/e85 you'll feel a bigger difference with the OTS tunes. I was too cheap to worry about custom tunes st that point
Old 02-05-2021, 06:02 PM   #35
DarkSunrise
Do you have any data logs with your flex fuel setup? Just want to see how much timing you’re running on the top end under open loop. On my OFT non-flex e85 tune I’m hitting 34-35 degrees timing advance with local e85. I’d be surprised if MBT was beyond that, but your post is making me curious what flex fuel tunes are aiming for.
2022 BRZ Build
2013 FR-S Build
Old 02-05-2021, 06:12 PM   #36
ermax
ermax's Avatar
Mmmm maybe, didn't really feel that significant to me, I was disappointed. Also a pain in the butt with the cold start thing, didn't like the backfires in the intake manifold. I'm wondering if part of it is the perceived difference from the available local pump (not referring to you specifically) - i.e. going from California 91 to E85 probably feels better than going from east coast 93. Or maybe a tune vs. setup thing. I just went FI - now that is a difference
I solved the cold start issues on mine just this week. In Florida we don't have cold weather long enough to push me to mess with it but this year it's been cold way more often than normal so I finally got around to fixing it. I am able to start right up on the first attempt down to 34F now. Wayne's E86 tune has the cold start fixes built in.
The Following User Says Thank You to ermax For This Useful Post:
bfrank1972 (02-08-2021)
Old 02-05-2021, 08:49 PM   #37
czellers
czellers's Avatar
Drives: 2K19 GT86
I'm in NC but its always in the garage where I doubt it gets below 40.. I grew up in Jacksonville FL though!
czellers is offline   Reply With Quote
The Following User Says Thank You to czellers For This Useful Post:
ermax (02-06-2021)
Old 02-05-2021, 10:18 PM   #38
Lantanafrs2
South Florida has e85 all over the place
Old 02-06-2021, 07:40 AM   #39
ermax
ermax's Avatar
Same in Jax, FL.
Old 02-06-2021, 08:23 AM   #40
bfrank1972
Yeah it is a CT thing.
Sent from my SM-G965U using Tapatalk
Old 02-06-2021, 02:43 PM   #41
Lantanafrs2
I'm from new haven originally so I get it lol
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
bfrank1972 (02-06-2021)
Old 02-08-2021, 04:21 PM   #42
vin08
275/1000
Drives: 2016 RS2 auto
gas is reaching $4 here in SoCal and E85 near my house that i just moved into 2 months ago is at 2.59. So i finally ordered a Flex fuel kit.
vin08 is offline   Reply With Quote
Looking to get new wheels - please advise ThaDonJsuan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-20-2021 02:51 PM
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 05:10 PM
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 09:02 PM
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 06:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 04:13 PM
