Old 03-02-2015, 02:45 PM   #1
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
New to rim fitment; someone please advise
Firstly, thanks for all the great stuff in this subforum! Lots of good information... However, numbers make my head hurt. So, if one of you wheel/rim fitment gurus could lend me a few moments of your time to answer a few questions:
Info on the rims I have that I want to mount:
17x6; +45 offset; 57.1 hub. Intend to mount 225/45R17 OR 215/45R17.
I have rims with a 57.1 hub bore and ours is 56.1... ...would I need hubcentric rings or not? If so, what size?
My guess is yes, but I'm not confident in that assumption (or the math).
Also, the rims will be almost 10mm MORE tucked into the wheel well. What are your recommendations for spacers to get "flush"? The general consensus to get the stockers flush is 15 in the front, 20 in the rear, yes? So with the extra 10mm; 20 front and 30 rear? Any safety concerns with a 30mm spacer? Are there any manufacturers that produce that size?
And lastly, thanks!
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
Old 03-02-2015, 03:11 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
first, why are you putting 17x6 wheels on the car? And I wouldn't put a 225 on a 6", stay with 215, if you HAVE to have these wheels on
hub bore-difference of .5mm...they don't have hubcentric spacers that small
lastly...it sounds like you're jumping through a lot of hoops to put wheels on this car that are not really the right size/offset. Money will be better spent on wheels that fit properly.
Old 03-02-2015, 03:24 PM   #3
REAV3R
Former Boost Junkie
REAV3R's Avatar
Meh... You might be right about the hoops bit! The rims are left over from a previous car so there's no cost involved expect to get them to fit right. I figure I'm not out much if I mount them.
Old 03-02-2015, 03:29 PM   #4
continuecrushing
yeah, it sounded like that from the first post!
I would try selling them, and use that cash toward new wheels.
Just cause its a lot of work to swap out lugs/spacers/bolt on spacers to end up with a "compromised" setup.
But, if you love the wheels, we can figure out how to make them work of course.
But at a minimum, you're adding some pretty big spacers(20mm or more) and buying new tires. Not horrible of course, when it comes to fitting wheels, if I have to run 10mm or larger spacers/bolt on spacers I'd rather just buy wheels that fit right from the go!
The Following User Says Thank You to continuecrushing For This Useful Post:
REAV3R (03-02-2015)
Old 03-02-2015, 03:37 PM   #5
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I've seen some guys around here use 20mm front and up to 30mm rear spacers for a flush look with oem wheels so that should give you an idea I wouldn't feel right using spacers bigger than that . The hub centric ring, you don't need for that 1mm difference and I think they don't make it anyways.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 03-02-2015, 03:45 PM   #6
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
They do. Although I agree you could do without them.
[ame="http://www.amazon.com/4pc-UberTechnic-Aluminum-Hubrings-56-1mm/dp/B00QN21GRU/ref=sr_1_1?s=automotive&ie=UTF8&qid=1425328803&sr= 1-1&keywords=56.1+to+57.1"]Amazon.com: 4pc - UberTechnic Aluminum Hubrings - 56.1mm Hub to 57.1mm Wheel - OD: 57.1mm ID: 56.1mm - Rings: Automotive[/ame]
I'm sure they don't look like the picture. I can imagine they would bend really easy too.
TheVoiceOfReason is offline   Reply With Quote
Old 03-02-2015, 03:50 PM   #7
yomny
yomny's Avatar
lol I stand corrected but yeah I think they would be very prone to breaking or bending. Amazon has everything lol, its like good for searching.
Old 03-02-2015, 03:55 PM   #8
adamg
Drives: brz
please dont put 17x6 wheels on. the stock wheels are tiny enough. prius wheels are probably bigger than that
adamg is offline   Reply With Quote
Old 03-02-2015, 04:00 PM   #9
yomny
yomny's Avatar
Agree, I know they're free and all but unless you just want to put them on a snap a pic then remove.. it'll affect negatively the handling characteristics of the car. I think a 225 is the biggest you should consider using and that'll probably pull the sidewall in.
The Following User Says Thank You to yomny For This Useful Post:
REAV3R (03-02-2015)
Old 03-02-2015, 04:43 PM   #10
REAV3R
Former Boost Junkie
REAV3R's Avatar
I'm not sure how those narrower rims would negatively affect handing; can you elaborate, please? It's understandable if the tire were more narrow, but if the tire retains its 215 width I would think there would be nominal differences. Granted, a 225 would have all kinds of sidewall flex going on, but I'm not sure about the 215. I'm not trying to be argumentative, I genuinely don't know. For what it's worth, I don't autocross or drift (well... Drift MUCH...).
Old 03-02-2015, 05:21 PM   #11
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
NWFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to NWFRS For This Useful Post:
2much (03-02-2015), continuecrushing (03-02-2015), REAV3R (03-02-2015)
Old 03-02-2015, 05:30 PM   #12
continuecrushing
lol...you could probably wrap a piece of paper around the hub for the same effect lol.
They would be tiny haha.
That was my bad haha, they were so thin I assumed they didn't exist
A wider wheel(up to a point) usually provides a stiffer sidewall for the tire, preventing it from rolling over.
225 on 6" works, but is usually not recommended. I came from srt-4's(turbo'd neons haha) and there was a LOT of debate about 225 on the stock 17x6 wheel...a lot of people did it, but it was generally not recommended.
Arguably, if you had a lighter weight wheel, you could be faster than a wider, but heavier wheel(say, same stock tires 215/45/17, but a 14lb 17x6 vs stock 20lbs 17x7). Or maybe the stiffer sidewall of the wider wheel would prevail? Don't know.
This thread will probably get derailed by idiots coming in here with complex math to prove me wrong, but just throwing out hypotheticals haha...
REAV3R (03-02-2015)
Old 03-02-2015, 05:31 PM   #13
REAV3R
Former Boost Junkie
REAV3R's Avatar
Perhaps I should clarify my previous statement: Other than the obvious wider-is-better for grip, please keep in mind I'm not looking to set records at the track. Optimally, I would run an 17x8 or 9. These are free, they're 5x100, and they don't look bad ('cept skinny)... I'm just curious as to what you all thought. If I said I was planning to ONLY use them for winter, would that make it better? (Ignore the fact that I'm in Hawaii... LOL)
Old 03-02-2015, 05:33 PM   #14
continuecrushing
Originally Posted by NWFRS View Post
was it the smoking tire that did the wheel swap on the mercedes by swapping all the wheels for spare tires to "simulate" increased power?
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 05:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 03:13 PM
Relationship advise? Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 821 07-10-2014 01:43 PM
Guys I can really use some advise... ScionFrsFan Engine, Exhaust, Transmission 27 12-31-2012 11:03 AM
Advise On Purchasing Fr-s Please! 7EASTAP Scion FR-S / Toyota 86 GT86 General Forum 7 09-18-2012 05:45 PM
