Old 02-04-2021, 12:32 PM   #15
ermax
ermax's Avatar
For me the biggest difference was with throttle blips. On 93 it pulls so much timing when blipping that often times your blips are completely ignored and you end up with a sloppy downshift. This never happens on E85.
One thing I've been working on this week is cold cranking. I'm in Florida so it's not normally much of an issue but anything bellow about 60F required two cranks. I made some adjustments to the cold cranking maps yesterday and it's much better but not perfect. This morning it cranked right up at 34F, ran for about 10secs and then stopped. Normally at 34F it would crank, start and instantly stop. So I've made progress.
The Following User Says Thank You to ermax For This Useful Post:
JesseG (02-05-2021)
Old 02-04-2021, 09:38 PM   #16
Purist
Purist's Avatar
Drives: Subaru BRZ
Originally Posted by jflogerzi View Post
Remember it's a little 2L engine. What you should feel is how smooth the car drives and the extra pull through the entire rev range.
Yep. Im disappointed for the OP. I felt the difference immediately, especially when accelerating at WOT. I also dropped a significant amount of time from my hillclimb runs.
I run my car on E85 100% of the time.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
JesseG (02-05-2021)
Old 02-04-2021, 10:05 PM   #17
jflogerzi
jflogerzi's Avatar
I run a blend ideally around E45 but at the track I go full e85
2013 Series 10 FRS #553
Old 02-04-2021, 10:34 PM   #18
DarkSunrise
DarkSunrise's Avatar
It may not feel like a big difference, but it's actually quite significant. On 5-90 mph runs in my FR-S against my friend's s2000, he would put 2-3 cars on me stock. With E85, we are even all the way. Another way to view it is E85 changes these from high 14 second 1/4 mile cars to low 14's.
I don't think any power adder on these cars can match the power/$ ratio of E85.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
JesseG (02-05-2021)
Old 02-04-2021, 10:37 PM   #19
jflogerzi
jflogerzi's Avatar
True but info do it right with flex fuel
Old 02-04-2021, 11:44 PM   #20
Purist
Purist's Avatar
Drives: Subaru BRZ
Admittedly it would be more convenient to not have to flash back to 98 when going cross country, but it only takes 5 min.
OFT is fine for 60-90% ethanol, but I'm pretty spoilt in that winter temps rarely go below 50 F, and I have access to pump fuel at a guaranteed 85% ethanol.
Less More
Old 02-05-2021, 11:26 AM   #21
DarkSunrise
Flex fuel definitely recommended, but I haven't had any issues running straight E85/OFT in my area. I've seen some minor variation in my LTFT's so there might be slight variations in ethanol content, but nothing beyond the adjustment window of the OFT (i.e., nothing below ~E60).
2022 BRZ Build
2013 FR-S Build
Old 02-05-2021, 11:48 AM   #22
bfrank1972
Drives: 2013 FR-S Argento
Mmmm maybe, didn't really feel that significant to me, I was disappointed. Also a pain in the butt with the cold start thing, didn't like the backfires in the intake manifold. I'm wondering if part of it is the perceived difference from the available local pump (not referring to you specifically) - i.e. going from California 91 to E85 probably feels better than going from east coast 93. Or maybe a tune vs. setup thing. I just went FI - now that is a difference
Old 02-05-2021, 12:27 PM   #23
Lantanafrs2
Drives: 2013 frs red
These things make 200whp na with header/e85. If you do the header first you're at 190 so the e85 is good for 10 horse after that. If you want to feel the difference, drive a stocker. You'll be amazed lol.
Lantanafrs2 is online now   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
czellers (02-05-2021)
Old 02-05-2021, 12:45 PM   #24
DarkSunrise
I think it’s because e85 doesn’t really change the shape of the NA torque curve. It adds 10-15 lbs-ft evenly across the powerband, which most people will think doesn’t feel like that much. But that area under the curve adds up.
I’m not surprised FI feels like a much bigger difference, it is! It’s probably 50 lbs-ft or more at certain parts of the powerband.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
bfrank1972 (02-05-2021), czellers (02-05-2021)
Old 02-05-2021, 12:51 PM   #25
czellers
czellers's Avatar
Drives: 2K19 GT86
This actually makes a lot of sense.. which is accurate in my case.. Catless header/overpipe/and full exhaust all prior to and stage2+ prior to stage2+ w/e85.. so basically, there wasnt much meat left on the bone for me hahah
czellers is offline   Reply With Quote
The Following User Says Thank You to czellers For This Useful Post:
Lantanafrs2 (02-05-2021)
Old 02-05-2021, 12:59 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's........not how that works.
Old 02-05-2021, 01:04 PM   #27
czellers
czellers's Avatar
Drives: 2K19 GT86
Old 02-05-2021, 01:09 PM   #28
bfrank1972
Yeah that's a good point - cumulatively it'll make a significant difference, just not so much with the butt dyno In the end it wasn't worth it because I live in CT, I think there are maybe 2 or 3 E85 stations in the WHOLE STATE. One happens to be 'close' in Greenwich, but that's still 1/2 hour drive for me :/
Looking to get new wheels - please advise ThaDonJsuan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-20-2021 02:51 PM
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 05:10 PM
New to rim fitment; someone please advise REAV3R Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 03-02-2015 09:02 PM
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 06:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 04:13 PM
