Old 06-11-2020, 12:16 PM   #15
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I have some extra gaskets I could sell for $30 shipped.
Jyn is offline   Reply With Quote
Old 09-08-2020, 09:46 AM   #16
PLX92
PLX92's Avatar
Drives: 2017 BRZ Premium
This is directed at the op, or anyone that has tired alternative solutions, has anyone had luck fixing these studs/nuts so that they do not work themselves out?
I found myself in the same predicament this past weekend, and this was after a pre-track check where I put a wrench on each of these nuts. Might just need to add a spare gasket kit to the track day tool kit.
PLX92 is offline   Reply With Quote
Old 09-08-2020, 10:01 AM   #17
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
So I ordered some of the Vibra-tite mentioned earlier in this thread and have had two successful track days without issue since. That's hardly proof of anything yet, but hoping the stuff is doing it's job.
Originally Posted by Lightened View Post
and then there is this stuff...
Vibra-TITE 19960 Hot-Lock Extreme High Temperature Ceramic Threadlocker
- Keeps assemblies from vibrating loose up to 2000°
- Great for muzzle brakes / recoil compensators, suppressors, vehicle exhaust bolts, turbocharger fasteners
- Water soluble for easy removal
captain awesome is offline   Reply With Quote
The Following User Says Thank You to captain awesome For This Useful Post:
Lightened (09-08-2020)
Old 09-08-2020, 10:47 AM   #18
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I have also used the Hot-lock with success, but no track days on mine.
The Following User Says Thank You to dragoontwo For This Useful Post:
Old 09-09-2020, 09:41 PM   #19
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i lost another stud so i think this is my 4th or 5th. i am running m8 bolts and nuts now
Old 09-10-2020, 10:01 PM   #20
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
This was the most frustrating part about the ace header when I ran one, and the odd leak like sound it makes.
skylinekin is offline   Reply With Quote
Old 09-11-2020, 07:24 AM   #21
Breadman
Breadman's Avatar
are you talking about the sound it makes in the mid range that sounds liek flowing water in the middle of your dash?
Old 09-11-2020, 12:45 PM   #22
skylinekin
skylinekin's Avatar
Uh yeaahh thats about right. I was told its just the rushing sound of exhaust thru the piping (thin walled). Got rid of that noise and the leaky overpipe gasket with a switch to the Tomei UEL.
Old 09-11-2020, 04:24 PM   #23
CSG Mike
CSG Mike's Avatar
Heat cycle and re-torque everything, as heat/vibration will make things back out.
Alternatively, replace the stud/nut with a bolt if you prefer, and then safety wire the bolt.
Using the cycle/retorque method, I had no issues with my header, but i did need to retorque 2-3 times after install before it stopped turning after cycling.
Old 09-13-2020, 07:21 PM   #24
Breadman
Breadman's Avatar
i lost the install sheet, what are the torque specs again?
The Following User Says Thank You to Breadman For This Useful Post:
Plumbus (12-07-2020)
Old 12-06-2020, 12:03 PM   #25
PLX92
PLX92's Avatar
Been a few months since this thread last popped up, but wanted to share my solution.
Actually ordered the hotlock, but still wasn't convinced I would be worry free long term.
Ended up ordering 20mm fasteners from drilledheadbolts.com and safety wired them through. (my first time using lock wire w/plies, not the tidiest job)
Happy to note i haven't had any issues here since.
[IMG][/IMG]
The Following 4 Users Say Thank You to PLX92 For This Useful Post:
captain awesome (12-06-2020), Code Monkey (12-06-2020), CSG Mike (12-08-2020), Plumbus (12-07-2020)
Old 12-07-2020, 01:14 AM   #26
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
[IMG][img]https://i.imgur.com/kWxdjiE.jpg?1[img][IMG]
What metric bolts are you guys running instead of the crappy included hardware? (head size, thread pitch, length?)
Plumbus is offline   Reply With Quote
Old 12-07-2020, 08:01 AM   #27
Breadman
Breadman's Avatar
im pretty sure it is an m8 nut but let me find the bolts. i know i tried a 30 and a 40 but i think the 40 was too long
Old 12-07-2020, 09:25 AM   #28
PLX92
PLX92's Avatar
M8-1.25 X 20MM did it for me, that was with a 2-3mm split washer under the bolt head.
The Following User Says Thank You to PLX92 For This Useful Post:
Installing used MY 2017 tail lights on MY 2012 86 - New gasket needed? AstroBoi Cosmetic Modification (Interior/Exterior/Lighting) 3 07-25-2019 07:23 AM
Wtb ace a350 headers Chriswongbrz Want-To-Buy Requests 0 05-26-2019 01:47 AM
WTH Ace A350 Header ionbomb Want-To-Buy Requests 0 02-18-2019 10:51 AM
SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive el-guapin Exterior Parts (Aero, Lighting, Etc.) 5 12-27-2018 02:54 AM
FS ACE Header A350 mtsound Engine, Exhaust, Bolt-Ons 0 09-14-2018 11:44 AM
