Wears Pants
Drives: 14 FRS K24 swap - SOLD
ACE a350 gasket needed, just one....
I had a couple studs work their way loose on my last track day, and it ended up destroying the 2 to 2 flange gasket. Does anyone know if I can get just that one gasket without buying the $50 kit?
It's the one in the middle of this pack. 86gsf by hatchethairy, on Flickr
#2 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
https://www.counterspacegarage.com/ace-gasket-gt86
| The Following User Says Thank You to weederr33 For This Useful Post: | captain awesome (06-11-2020) |
#3 | |
Wears Pants
I'm not sure how I missed that, thanks! |
Drives: GT86 2013
I like Remflex. I bought Remflex GS16511 and made my own gasket for my Ace350.
Drives: 2017 BRZ (Sold), 2023 GR86
This has happened twice to me at track days. I bring a spare just in case now!
Wears Pants
I think it's a mix of a not-so-great flange/bolt design and me perhaps not torqueing down the nuts enough. That said, two reputable race shops have tried some alternate nut/bolt setups and I still lost a nut or two out on track.
It still lingers in the back of my mind every time I head out for a session. Everything held on during a track day last month though. I'm thinking about doing some sort of safety wire setup in the next few weeks before I go back out. |
#9 | ||
Drives: Crapcan
#10 |
Every Ounce Counts
Drives: 86
The gasket itself is durable and does not fall apart... the bolts may back out from vibration + heat.
At least the replacement gasket comes with new nuts and bolts. ![]() and then there is this stuff... Vibra-TITE 19960 Hot-Lock Extreme High Temperature Ceramic Threadlocker - Keeps assemblies from vibrating loose up to 2000° - Great for muzzle brakes / recoil compensators, suppressors, vehicle exhaust bolts, turbocharger fasteners - Water soluble for easy removal
| The Following 4 Users Say Thank You to Lightened For This Useful Post: |
#11 |
Wears Pants
Glad to hear new hardware is in with it. I also ordered up some of that Hot Lock so maybe this will be my last time messing with it.
#12 | |
Drives: 22 BRZ limited
Not sure how much you actually looked into it, but it looks like the product needs heat to fully cure. Idling for 5 and a cool down looks like it will easily set it. |
#13 | |
Wears Pants
I just clicked on the buy button. Thanks for the heads up though, I'll make sure to give it some heat for a bit for proper cure procedure. |
#14 | |
Drives: 2017 BRZ w/PP
im not sure if there is room but i should try and see. ive had the bottom single one fall out on my before |
| The Following User Says Thank You to Breadman For This Useful Post: | NoHaveMSG (06-11-2020) |
| Installing used MY 2017 tail lights on MY 2012 86 - New gasket needed? | AstroBoi | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-25-2019 07:23 AM |
| Wtb ace a350 headers | Chriswongbrz | Want-To-Buy Requests | 0 | 05-26-2019 01:47 AM |
| WTH Ace A350 Header | ionbomb | Want-To-Buy Requests | 0 | 02-18-2019 10:51 AM |
| SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive | el-guapin | Exterior Parts (Aero, Lighting, Etc.) | 5 | 12-27-2018 02:54 AM |
| FS ACE Header A350 | mtsound | Engine, Exhaust, Bolt-Ons | 0 | 09-14-2018 11:44 AM |
