Old 06-08-2020, 08:54 AM   #1
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
ACE a350 gasket needed, just one....
I had a couple studs work their way loose on my last track day, and it ended up destroying the 2 to 2 flange gasket. Does anyone know if I can get just that one gasket without buying the $50 kit?
It's the one in the middle of this pack.
86gsf by hatchethairy, on Flickr
captain awesome is offline   Reply With Quote
Old 06-08-2020, 09:08 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Here you go:
https://www.counterspacegarage.com/ace-gasket-gt86
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
captain awesome (06-11-2020)
Old 06-08-2020, 09:25 AM   #3
captain awesome
Wears Pants
Originally Posted by weederr33 View Post
I'm not sure how I missed that, thanks!
Old 06-08-2020, 10:19 AM   #4
mrjj
Drives: GT86 2013
I like Remflex. I bought Remflex GS16511 and made my own gasket for my Ace350.
mrjj is offline   Reply With Quote
Old 06-09-2020, 11:50 PM   #5
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
This has happened twice to me at track days. I bring a spare just in case now!
mistople is offline   Reply With Quote
Old 06-10-2020, 02:58 PM   #6
norcalpb
norcalpb's Avatar
Does it just get so hot that things start to fall apart?
Old 06-10-2020, 03:08 PM   #7
captain awesome
Wears Pants
That's not what I wanted to read. At all. I didn't loctite the studs on the first install so maybe this go around I will. It's $40 shipped for just one gasket!
Old 06-10-2020, 05:36 PM   #8
mistople
mistople's Avatar
I think it's a mix of a not-so-great flange/bolt design and me perhaps not torqueing down the nuts enough. That said, two reputable race shops have tried some alternate nut/bolt setups and I still lost a nut or two out on track.
It still lingers in the back of my mind every time I head out for a session. Everything held on during a track day last month though. I'm thinking about doing some sort of safety wire setup in the next few weeks before I go back out.
Old 06-10-2020, 06:14 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Most loctite is not good for heat, no point in putting it on exhaust parts.
Is there enough room on that flange for a flanged nut? I have these at work. They are 3/8-24 two piece non marring locking flange nuts.
Old 06-10-2020, 08:00 PM   #10
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
The gasket itself is durable and does not fall apart... the bolts may back out from vibration + heat.
At least the replacement gasket comes with new nuts and bolts.
and then there is this stuff...
Vibra-TITE 19960 Hot-Lock Extreme High Temperature Ceramic Threadlocker
- Keeps assemblies from vibrating loose up to 2000°
- Great for muzzle brakes / recoil compensators, suppressors, vehicle exhaust bolts, turbocharger fasteners
- Water soluble for easy removal
Lightened is offline   Reply With Quote
The Following 4 Users Say Thank You to Lightened For This Useful Post:
captain awesome (06-11-2020), CSG Mike (06-15-2020), Lonewolf (12-09-2020), NoHaveMSG (06-10-2020)
Old 06-11-2020, 08:00 AM   #11
captain awesome
Wears Pants
Glad to hear new hardware is in with it. I also ordered up some of that Hot Lock so maybe this will be my last time messing with it.
Old 06-11-2020, 09:14 AM   #12
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Not sure how much you actually looked into it, but it looks like the product needs heat to fully cure. Idling for 5 and a cool down looks like it will easily set it.
Old 06-11-2020, 10:10 AM   #13
captain awesome
Wears Pants
I just clicked on the buy button. Thanks for the heads up though, I'll make sure to give it some heat for a bit for proper cure procedure.
Old 06-11-2020, 10:54 AM   #14
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
im not sure if there is room but i should try and see. ive had the bottom single one fall out on my before
The Following User Says Thank You to Breadman For This Useful Post:
NoHaveMSG (06-11-2020)
Installing used MY 2017 tail lights on MY 2012 86 - New gasket needed? AstroBoi Cosmetic Modification (Interior/Exterior/Lighting) 3 07-25-2019 07:23 AM
Wtb ace a350 headers Chriswongbrz Want-To-Buy Requests 0 05-26-2019 01:47 AM
WTH Ace A350 Header ionbomb Want-To-Buy Requests 0 02-18-2019 10:51 AM
SOLD: Brand New 2 Sets Of Gasket Ninja Tailight Gasket Kit With 3M Adhesive el-guapin Exterior Parts (Aero, Lighting, Etc.) 5 12-27-2018 02:54 AM
FS ACE Header A350 mtsound Engine, Exhaust, Bolt-Ons 0 09-14-2018 11:44 AM
