Old 08-06-2020, 06:29 PM   #1
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
BRZ MT hard to put in gear when warmed up
I have a ACT lightweight flywheel street clutch kit. This problem arised recently after a UEL Header install as well as a whiteline transmission bushing install. When the car is off I am able to shift freely, when I turn it on for the first time of the day or if the car is cool, I can shift to all gears freely. However, once I start driving and the car has warmed up, it feels as if, only from a stop, when I shift I hit a wall and I can't put the car in gear unless I rev the car to like 3500 rpms, or try to put it into another gear and if one is open then I can, while the clutch is still depressed, shift out of that gear and into first. Obviously, drive thru's and red lights I do not enjoy right now.. so if there is anybody that has had experience or knowledge on this could offer some advice I would really appreciate it �� happy 8/6 day btw ��
Edit: I installed the clutch kit about 9 months before the problems began.
toughguy39 is offline   Reply With Quote
Old 08-06-2020, 06:31 PM   #2
Ashikabi
Ashikabi's Avatar
Check clutch pedal adjustment
Sent from my ONEPLUS A5010 using Tapatalk
Old 08-06-2020, 06:52 PM   #3
toughguy39
toughguy39's Avatar
I think this may be it. Looks a little overextended.
Old 08-06-2020, 07:03 PM   #4
Ashikabi
Ashikabi's Avatar
I'm not sure what symptoms over extension causes, but underextension causes your clutch to only partially disengage which locks you out of gears
Old 08-06-2020, 07:09 PM   #5
toughguy39
toughguy39's Avatar
Hmm.. is it possible It needs more extension this far out bc that's exactly what is happening.
Old 08-06-2020, 08:34 PM   #6
toughguy39
toughguy39's Avatar
Adjusted and tested several points, will confirm that clutch pedal adjustment is not the problem.
Old 08-06-2020, 08:47 PM   #7
Ashikabi
Ashikabi's Avatar
That's shitty. Cuz that's the easy fix
Old 08-06-2020, 10:24 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
Check the clutch master cylinder, slave cylinder and line for leaks. Also check your fluid levels.
1974 TA22 Celica
2013 86 GT
Old 08-06-2020, 10:55 PM   #9
Ashikabi
Ashikabi's Avatar
Maybe silly but... Did you bleed it?
Old 08-06-2020, 11:22 PM   #10
toughguy39
toughguy39's Avatar
The fluid levels are good, all of them are. Going to flush and replace/bleed the brake/clutch fluids this weekend or tomorrow, and change transmission oil to motul 300. Hopefully one of those does it
Old 08-07-2020, 04:25 PM   #11
toughguy39
toughguy39's Avatar
Replaced and bled the clutch fluid, the problem persists..
Old 08-09-2020, 02:54 AM   #12
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Unfortunately, might be clutch drag endemic to ACT clutches.
Happened to me: https://www.ft86club.com/forums/showthread.php?t=128871. I personally know of it happening in another instance to my friend. Both ACT
EndlessAzure is offline   Reply With Quote
Old 08-09-2020, 11:20 PM   #13
dholloway543
Software Hobbiest
Drives: 2015 FRS
I had the same problem with the ACT clutch it didn't go away untill the clutch killed itself from clutch drag. I even did steel braided clutch cables, forged clutch fork, and high temp clutch fluid. Something that helped out a lot though was getting a solid shifter mount. Their like 30 dollars online and a lot of work but worth it. If its anything like this video. Now im running the exedy stage 2 clutch and its holding up to my 400-450hp.
If it is like that just get ready for winter because it gets worse in the cold.
dholloway543 is offline   Reply With Quote
Old 08-10-2020, 09:00 AM   #14
ML
ML's Avatar
Drives: 13 White MT FR-S
Yup ACT is shit basically.
Difficulty going into 1st and 2nd gear when car is warmed up Kai Uhl Engine, Exhaust, Transmission 3 11-05-2019 02:08 AM
Clunky and hard gear shifts nhuyvan1106 Issues | Warranty | Recalls / TSB 45 08-26-2017 01:52 PM
Can't get into any gear from a stop once car is warmed up Pneub Engine, Exhaust, Transmission 34 04-23-2014 11:50 AM
Can't get into any gear from a stop once car is warmed up Pneub Issues | Warranty | Recalls / TSB 5 04-04-2014 02:32 AM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
