Old 04-03-2014, 04:41 PM   #1
Pneub
Drives: Dark Grey BRZ
Can't get into any gear from a stop once car is warmed up
So I've been having problems for a little while now. It was always a bit notchy getting into gear even before modifications but it wasn't bad enough to warrant putting anything off. After replacing the clutch, I'd say in the range of 3k miles, I started having trouble getting into gear if the car came to a complete stop. This applied to all gears not just first gear. The only way for me to get into gear was to slide into first as I rolled into the stop and just keep the clutch down until traffic started moving again. If I didn't do that I'd have to slam it into either first or third which then allowed me to get into first no problem. That got old after awhile and because the problem was getting into all gears and not just first (figured it would be a syncro) I decided to replace the clutch. This fixed the problem again for about 2000 miles. Now it's back and I can't figure out what's wrong.
-Car goes into any gear fine when cold. Usually takes about 5-10 minutes of driving after warming up the car for the gears to get sticky. When the car is cold everything is very smooth.
-After the car is warm I can't get into any gear at all. If I do get locked out I can usually slam it into third which then allows me to easily get into first.
-This also applies to reverse.
-Changing the clutch fixes the problem for a couple thousand miles and then the problem returns. I also changed out to a slightly heavier flywheel the second time around.
Pneub is offline   Reply With Quote
Old 04-03-2014, 06:08 PM   #2
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
put stock clutch back in
take it to the dealership
EvilBeaverFace is offline   Reply With Quote
Old 04-03-2014, 06:18 PM   #3
Tainen
Drives: First SWP BRZ-L
What fluids are you running in the tranny? What have you put in there to try and fix this?
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-03-2014, 06:27 PM   #4
Pneub
It would be quite difficult to get back to stock considering all the work done
Old 04-03-2014, 06:29 PM   #5
Pneub
I'm not entirely sure but I do know I've had the differential fluid changed twice now. It made the shifting a lot smoother in all gears but never seemed to have any affect when it came to getting into gear from stock. Evasive Motorsports has done the fluid changes a couple times and they don't seem to understand what is wrong either.
Old 04-03-2014, 06:33 PM   #6
Tainen
Fluids have a pretty large impact on shift feel and smoothness, I'd probably call your shop and ask what fluids they've been using on the tranny flushes. There might be other fluid options that will give you a much better experience.
Old 04-03-2014, 06:41 PM   #7
Pneub
I believe the transmission fluid was Motul Gear 300 75w90. I've flushed it twice now.
Old 04-03-2014, 06:43 PM   #8
Tainen
ok. Then definitely your next choice is to find a good local dealership that doesn't flip too much crap about mods, and take it in.
Old 04-03-2014, 06:46 PM   #9
Pneub
I don't see that happening. I'm going to have to pay for this to be fixed myself
http://www.import-addicts.com/home/w...013/08/241.jpg
Old 04-03-2014, 06:48 PM   #10
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
bleed the clutch hydraulic system and then adjust the clutch master to get the correct throw when hot. You can't engage gears as the clutch plate is dragging.
JP is offline   Reply With Quote
Old 04-03-2014, 06:53 PM   #11
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
it sounds like the modifications are what is causing you problems.
i would bring it to stock levels (can probably leave your current clutch on there now) and see.
subiestyle is offline   Reply With Quote
Old 04-03-2014, 07:23 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
seconded.
Old 04-03-2014, 07:26 PM   #13
Pneub
I sent this over to Evasive to see if that could be the issue. Thank you.
Old 04-03-2014, 07:31 PM   #14
wheelhaus
wheelhaus's Avatar
Thirded.
I agree it's likely the clutch is dragging. A few things could cause this:
1- If the clutch pedal engagement is set too low, then there might not be enough pedal travel to fully separate the plates.
2- Air in the clutch hydraulic system (stated above).
3- faulty clutch (or somehow incorrect model installed).
4- faulty installation.
wheelhaus is offline   Reply With Quote
At stop lights, do you stay in gear or go into neutral? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 77 07-25-2014 09:23 PM
Can't get into any gear from a stop once car is warmed up Pneub Issues | Warranty | Recalls / TSB 5 04-04-2014 02:32 AM
Coasting to a stop in higher gear subiestyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-28-2014 05:31 PM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
