Old 04-03-2014, 04:41 PM   #1
Pneub
Drives: Dark Grey BRZ
Can't get into any gear from a stop once car is warmed up
So I've been having problems for a little while now. It was always a bit notchy getting into gear even before modifications but it wasn't bad enough to warrant putting anything off. After replacing the clutch, I'd say in the range of 3k miles, I started having trouble getting into gear if the car came to a complete stop. This applied to all gears not just first gear. The only way for me to get into gear was to slide into first as I rolled into the stop and just keep the clutch down until traffic started moving again. If I didn't do that I'd have to slam it into either first or third which then allowed me to get into first no problem. That got old after awhile and because the problem was getting into all gears and not just first (figured it would be a syncro) I decided to replace the clutch. This fixed the problem again for about 2000 miles. Now it's back and I can't figure out what's wrong.
-Car goes into any gear fine when cold. Usually takes about 5-10 minutes of driving after warming up the car for the gears to get sticky. When the car is cold everything is very smooth.
-After the car is warm I can't get into any gear at all. If I do get locked out I can usually slam it into third which then allows me to easily get into first.
-This also applies to reverse.
-Changing the clutch fixes the problem for a couple thousand miles and then the problem returns. I also changed out to a slightly heavier flywheel the second time around.
Pneub is offline   Reply With Quote
Old 04-03-2014, 06:50 PM   #2
humfrz
hmmm.......I suggest you check the clutch/brake fluid reservoir.
Next, bleed the clutch system.
If that doesn't fix it, I'd check the clutch adjustment.
humfrz
Old 04-03-2014, 11:26 PM   #3
Ozzman
Drives: old
Your clutch is dragging, either by not disengaging properly or failure of some sort. Also a possible pilot bearing problem.
Ozzman is offline   Reply With Quote
Old 04-04-2014, 02:19 AM   #4
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
I have the same issue, havent addressed it yet as car is waiting on parts.
Have you tried changing tranny fluid?
ahaghshenas is offline   Reply With Quote
Old 04-04-2014, 02:24 AM   #5
pitstops
Drives: SC RB FRS
could be a bad clutch master and slave cylinder issue. when those go bad you cant get into gear. ebay has a used one for $40.
bleeding the system might help too.
pitstops is offline   Reply With Quote
Old 04-04-2014, 02:32 AM   #6
evan
Drives: fr-s
I had the exact same problem with an ACT clutch. It's not the hydraulics. I had to go to an EXEDY clutch to try to solve the problem. The throwout bearing in mine was also noisy as hell. The manual trans/clutch in these cars is finicky at best. When cold, no issue (unless winter temps). Once it got hot, trying to get into gear was not happening.
evan is offline   Reply With Quote
first gear shift clutch
At stop lights, do you stay in gear or go into neutral? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 77 07-25-2014 09:23 PM
Coasting to a stop in higher gear subiestyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-28-2014 05:31 PM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
