Old 07-19-2020, 12:37 AM   #1
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Brake rotor damaged in shipping = still ok?
Hi,
I received my Centric front rotors, and one of them is damaged on the interior edge. It almost looks like it was grinded by something?!?
I'd like to have your opinions if it could be a problem, or if it's just cosmetic issue.
I track the car.
My options would be
1- Return the rotor for an exchange (would really like to avoid that hassle if possible)
2- Run it like that, hoping it's not going to vibrate or be unbalanced or crack.
3- Maybe use a grinder/dremel to remove a similar amount of metal on the other side (180deg), to balance things
See pictures, for reference the damage on the left is 1 inch long.
nico_rsx is offline   Reply With Quote
Old 07-19-2020, 02:18 AM   #2
ls1ac
ls1ac's Avatar
Call, talk to them see what they say. Hard to figure what happened. was it sealed in the bag? Was there a piece in the bag?
Old 07-19-2020, 09:43 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
I would get a replacement unless they can verify its good
DarkPira7e (07-19-2020)
Old 07-19-2020, 09:51 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The last thing you want is to be worrying about one of the few things that help save your ass in an emergency, get it replaced.
You paid for it initially because you didn't want to worry, right?
Old 07-19-2020, 10:11 AM   #5
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
it almost looks like a machine mark for balancing the rotor on the edge but the root of it looks like a chip. cant tell from the pictures.
the vanes should be smooth to promote laminar not turbulent flow so the most heat is removed at the surface. that's extremely rough where the black paint is.
send them back at get OE rotors, Zimmerman, sebro, ect
thomasmryan is offline   Reply With Quote
Old 07-19-2020, 03:05 PM   #6
nico_rsx
There was no piece inside the bag. The bag was teared at this exact spot, and the box damaged at this spot also. So it was damaged once in the manufacturer box (but the distributor shipping box was ok).
Old 07-19-2020, 03:09 PM   #7
nico_rsx
It's not to balance. The bag was teared and box damaged at this exact spot.
Centric rotors has been used by a lot of people on the track and are fine for light track duty (when they are not damaged, at least...)
Old 07-20-2020, 09:27 AM   #8
Racecomp Engineering
Tracking the car? I would want an exchange. A weak point in the rotor like that would make me nervous and I'd expect cracks to start there a lot sooner than they should.
- Andrew
nico_rsx (07-20-2020)
Old 07-20-2020, 11:08 AM   #9
Grady
Grady's Avatar
They do machine brakes in that area to balance, however that looks like a chip. A brake component is critical. I would not accept a “it will be ok” answer. Get a new one that is not damaged. You paid for it!
The Following 2 Users Say Thank You to Grady For This Useful Post:
nico_rsx (07-21-2020), Ohio Enthusiast (07-20-2020)
Old 07-20-2020, 11:35 AM   #10
Evan55
Drives: 06 Exige, 17 BRZ PP
With a picture, they should send you a new one without requiring you to send that one back. Should be relatively painless.
If they do in fact want you to send it back they should provide a shipping label since its defective.
Evan55 is offline   Reply With Quote
The Following User Says Thank You to Evan55 For This Useful Post:
Old 07-20-2020, 03:14 PM   #11
racingfool
racingfool's Avatar
Drives: Miata
I want an exchange even if I'm not tracking the car.
Yep
racingfool is offline   Reply With Quote
The Following 2 Users Say Thank You to racingfool For This Useful Post:
nico_rsx (07-21-2020), Racecomp Engineering (07-20-2020)
Old 07-20-2020, 08:14 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
If it were me, I'd look over the whole thing closely and barring anything else like cracking or out-of-roundness - I'd run it (on the racecar).
It's 'functionally' a block of iron and it looks like maybe it dropped on cement just right and chipped off a tiny bit of metal. In fact, because Centric has good quality controls and generally makes good stuff - I'd bet you're safer with this on your car than an over-the-counter Autozone special made in china that get's put on millions of cars year.
PRO86 | WTCC | STL
Old 07-21-2020, 02:26 PM   #13
nico_rsx
I contacted the seller, and he sent me a return label and agreed to exchange it.
So one less thing to worry that may or may not break on the track
Thanks guys
The Following User Says Thank You to nico_rsx For This Useful Post:
CSG Mike (07-21-2020)
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
Brake Rotor is loose!? AnthonyArcaro Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 07-19-2018 06:38 AM
Brake Pads + Rotor Mikeez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-01-2015 09:34 AM
Brake Rotor Runout gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-20-2015 12:43 PM
wheel got damaged during shipping bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 11 08-05-2013 10:53 PM
