Drives: 2014 White Subaru BRZ Limited
Brake Rotor is loose!?
So I recently replaced my brakes with the StopTexh Brake kit. I installed the brake rotors, pads and braided brake lines as well as flushed the fluid. The breaks ha e no air in them and they feel great.
The other day i took a wheel off just to check the brakes to make sure everything stayed torqued down and noticed that the rotor had a little bit of play to it!? Is this simply because the only thing holding it tightly to the hub is the lug nuts themselves? Or did I mess something up? I made sure everything was torqued down to spec?
Daily 2014 Satin White Pearl BRZ Limited
Instagram: @subyota |
86 Challenge
Drives: 2017 BRZ
If it’s anything like my performance pack rotors, it’s just a snug fit on the hub and they can be moved with the wheel off.
| The Following User Says Thank You to mkodama For This Useful Post: | Spuds (07-18-2018) |
Drives: 2014 BRZ Limited
The rotor with have play with the wheel off until it seizes to the hub.
| The Following User Says Thank You to elitegunslinger For This Useful Post: | Spuds (07-18-2018) |
A.K.A. Starlord
Drives: 2015 Series.Blue
The only thing keeping the rotor in place once you take off the wheel, is the caliper, which shouldn't be holding it so hard that you can't move it unless it is sticking.
So yes, that is normal.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#5 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | chaoskaze (07-18-2018), Ultramaroon (07-18-2018) |
Luckily we have the threaded holes in the rotor hat to insert a bolt and push the rotor off the hub.
In theory. Most rotors have them but I have come across ones on some junkers I drove that refused to budge. The car has to have reached a very special level of neglect but it happens.
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (07-18-2018) |
#8 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Yes to the OP considered yourself blessed that the originals ones were easy to remove. I always put some Anti-Seize on the hub surface when changing rotors
#9 | |
Totally normal. |
#10 |
not playing cards
#12 |
Famous Potatoes
Drives: '15 ultramarine
I've had luck in the past hitting the stubborn ones on one side with the sledgehammer.
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (07-18-2018) |
#13 |
Only users lose drugs.
Drives: All the time
Blue wrench and a 5 pound lump mallet.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#14 |
| DIY: Front Brake Pad and Brake Rotor Replacement | F1point4 | DIY (Do-It-Yourself) Guides | 28 | 03-21-2021 09:22 PM |
| brake rotor need replace? | ZHoward | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-23-2016 03:11 PM |
| Brake Pads + Rotor | Mikeez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-01-2015 09:34 AM |
| Brake Rotor Runout | gdrider77 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-20-2015 12:43 PM |
| R1 Concepts rotor, and brake pads | ExtremeAutowerks | Brakes, Suspension, Chassis | 37 | 12-23-2013 02:39 PM |
