Old 04-06-2020, 07:55 PM   #1
Molez93
Scott M
Molez93's Avatar
Drives: '13 BRZ (DocWalt's old car)
Metal ball on the tranny drain plug magnet. What gives?
Any ideas what the heck is going on here?
I found a small metal ball (ball bearing?) on the tranny drain plug along with the expected metallic sludge. I took a picture of that ball next to my key (for sizing). That pic and a screenshot of a transmission schematic are included here. There are a couple "possible" sources of that ball based on the schematic, but without taking the case apart have zero idea what the likely (typical?) source would be for the one on the magnet. More importantly, is this going to become a big deal?
The gear box has never given me any problems in a little more than 1.5 years of ownership, including ~100 autocross runs, ~6 track days, and ~9000 miles total. The 1-2 cold shift was never great, but it always got better after a few miles of driving.
Thank for any ideas you have!
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240
06 BMW Z4M Roadster, 20 M850
Molez93 is offline   Reply With Quote
Old 04-06-2020, 08:21 PM   #2
Infinity
Drives: 2016 Scion FR-S
I don't have an answer for you, but that would make me super nervous!
Infinity is offline   Reply With Quote
Old 04-06-2020, 08:35 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
A big wtf from me too.
Did you hear it drop into the pan or was the ball bearing already in the pan?
Old 04-06-2020, 09:36 PM   #4
Molez93
Scott M
Molez93's Avatar
I heard nothing. The time had simply come to refresh the drivetrain fluids. Was just cleaning off the drain plug, checking out the sludge and found it. I've never replaced/drained my own tranny or diff fluid before, but the transmission fluid was definitely in worse shape than the differential.
13 BRZ (DSTprep)
Old 04-06-2020, 09:52 PM   #5
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
If the transmission is working fine, forget about it and keep driving.
Your other 2 options are to lose sleep worrying about it or start doing exploratory and disassemble the transmission.
Old 04-06-2020, 09:58 PM   #6
Molez93
Scott M
Molez93's Avatar
I already shopped for used trannys on eBay. $500 and an opportunity to do my first transmission swap if it fails... could be worse. I'm definitely prepared to just drive it- heck, I was already.
Would be nice to know wtf happened though.
13 BRZ (DSTprep)
Old 04-06-2020, 11:59 PM   #7
86TOYO2k17
Drives: 2017 toyota 86
If it was an auto id have a good guess.
Just do a couple hard pulls back to back, if it still works fine after that. Free weight reduction?
Old 04-07-2020, 02:52 AM   #8
alan.chalkley
Drives: 4wd zooks
Lucky you got it out before it took a ride through the gears!
alan.chalkley is offline   Reply With Quote
Old 04-07-2020, 07:25 AM   #9
Code Monkey
Drives: Subaru BRZ
You will need a new transmission, sooner rather then later, linky.
Code Monkey is offline   Reply With Quote
Old 04-07-2020, 09:15 AM   #10
Molez93
Scott M
Molez93's Avatar
Thanks for that. Interesting and possibly helpful- consistent with my expectation at this point at least.
13 BRZ (DSTprep)
Old 04-07-2020, 10:55 AM   #11
Grady
Grady's Avatar
Originally Posted by solidsnake11 View Post
Maybe it got dropped during assembly and they installed another. Now you have a spare.
That is a large possibility, especially if this is the first change.
Old 04-07-2020, 12:43 PM   #12
Molez93
Scott M
Molez93's Avatar
Decent chance it’s the first change. Bought it from the second owner with 32k on all but the engine (that had 70k+). It saw a lot of autocross and track time with them, and still with me.
It’s the only twin I’ve spent any real time driving, other than 20 min in my friend’s FRS. Seems to shift the same as that one from what I can recall.
13 BRZ (DSTprep)
Old 04-08-2020, 05:27 PM   #13
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
thankfully they put magnetic plugs in the gearbox!
sneaky_pete is offline   Reply With Quote
Old 04-08-2020, 05:43 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
totalled. time to buy a civic.
Need help extracting drain plug... SamtheKorean Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 01-25-2020 05:18 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 06:20 PM
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)? Daedex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-05-2014 08:50 PM
Drain Bolt Magnet? Anorexic 86 Issues | Warranty | Recalls / TSB 35 09-21-2012 03:08 AM
