That One Guy
Drives: White 2017 BRZ
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)?
I just bought 4 quarts of Motul Gear 300 75w-90 for the differential and transmission fluid change, but i was thinking that if these drain plugs do not come stock with a magnetic drain plug, i was going to buy some.
Anyone know this? Also, what are the specs/size of the drain plugs? If anyone has bought some magnetic drain plugs for these, post a link if you can. Thanks in advanced.
"I am not bound to win, but I am bound to be true."
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=19218
Short answer: yes. Long answer: 99.99999% of RWD manual transmission cars have magnetic drain plugs. Otherwise the transmission won't last that long from contamination. -alex |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Greddy magnetic drain bolt | thisisthenewsic | Engine, Exhaust, Bolt-Ons | 2 | 04-23-2014 08:44 PM |
| Magnetic oil drain plug, effective? | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 02-16-2013 11:59 PM |
| Greedy Magnetic Drain Plug | USMC -FRS | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 02-10-2013 06:04 PM |
| GReddy Magnetic Drain Plug BRZ/FRS at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 2 | 01-05-2013 10:19 PM |
