Old 04-05-2020, 09:58 PM   #1
Nidalas
Drives: Gt86
Main bore housing size
Does anybody know what are the specs for the main bore housing for these engines?
Nidalas is offline   Reply With Quote
The Following User Says Thank You to Nidalas For This Useful Post:
humfrz (04-05-2020)
Old 04-05-2020, 11:18 PM   #2
Welcome to our forum, Nidalas -
What do you mean by the "main bore housing"?
Old 04-06-2020, 12:38 AM   #3
Halo_2
Drives: 2014 MY15 86 GTS
86mm bore 86mm stroke
Halo_2 is offline   Reply With Quote
Old 04-06-2020, 01:12 PM   #4
Nidalas
Drives: Gt86
86mm is the cylinder bore and stroke, I'm looking for the main housing diameter specs it's for my machinist to perform an align hone.
Old 04-06-2020, 11:26 PM   #5
I scraped this off the internet, you may wish to verify.
HOUSING BORE SPEC'S
2.8755"
73.037 mm
Old 04-07-2020, 09:14 AM   #6
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
What is a housing bore?
Edit, or a bore housing?
Old 04-07-2020, 01:26 PM   #7
entaroadum
Drives: 2013 Subaru BRZ
HOUSING BORE SPEC'S
2.8755"
73.037 mm
I made some calculations using bearing thickness, crank journal diameter and oil clearance and it should be around:
#1-4
mm 73.001 - 73.097
in 2.8740 - 2.8778
#5
mm 72.997 - 73.093
in 2.8739 - 2.8777
Again, this is my own calculation as the was no mention of this in the service manual. I have a bare block in my shop I want to double check with but can't because of the quarantine. I'll circle back to this thread when I have the chance.
entaroadum is offline   Reply With Quote
Old 04-07-2020, 02:20 PM   #8
fika84
fika84's Avatar
This image should have all the information you need to calculate the bore in the block for the crank and bearings.
The below image is from my 2013 manual, I'm not sure if it changed through the years or not.
fika84 is offline   Reply With Quote
Old 04-08-2020, 06:30 PM   #9
A house (housing) bore is what mrs humfrz is calling me during this period of isolation.
Spuds (04-08-2020)
Main journal size mark on block entaroadum Engine, Exhaust, Transmission 4 07-24-2021 01:13 AM
Bore size help Krewmaui Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-22-2015 12:02 PM
Series.Blue hub bore size lugao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-02-2015 10:51 AM
Can someone with a BRZ limited measure the foglamp size (housing not bulb) Norkoastal Cosmetic Modification (Interior/Exterior/Lighting) 0 08-27-2012 11:31 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
