Old 04-01-2015, 02:21 PM   #1
lugao
Drives: 2015 Subaru BRZ Series.Blue
Series.Blue hub bore size
Hello, I currently own a 2015 BRZ Series.Blue. Tried fitting the RPF1 17x7+42 with a bore size of 56.1 but it doesn't fit. Do you guys happen to know if they changed the bore size of the BRZ? Thank you in advance!
lugao is offline   Reply With Quote
Old 04-01-2015, 02:25 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
usually they provide a hub centric ring.
did you check your box if they had one?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 04-01-2015, 02:30 PM   #3
lugao
The problem is that my hub is bigger than the hold on my rims. You would need hub centric rings if your hub is smaller than your wheel's hole
Old 04-01-2015, 02:49 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
You sure it's 56.1 centerbore on the wheel?
I assume this is a special order wheel, most I see are a 73.1mm and only a 15" produced with a CB smaller than 56.1
Old 04-01-2015, 02:55 PM   #5
lugao
Yes, I am sure. I bought the set of rims from a 2013 BRZ owner.
Old 04-01-2015, 03:05 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Silly question, but you don't happen to have centering rings from a different wheel that stuck to your hub?
I don't know that things have or have not changed, but that's pretty unlikely since 56.1 is even found on the 5x114.3 Subarus.
Old 04-01-2015, 04:02 PM   #7
lugao
I thought I left a ring on there but there isn't
Old 04-01-2015, 04:37 PM   #8
wparsons
wparsons's Avatar
Hubs are identical across the regular models and special editions, something else is at play.
flickr
Old 04-01-2015, 04:41 PM   #9
lugao
Sounds good! Thank you! I wonder if there is something wrong with my wheels
Old 04-01-2015, 04:52 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
did you check the hub of your car? It might be dirty/rusty/have gunk on it.
We see it at work all the time!
Old 04-02-2015, 10:33 AM   #11
lugao
I cleaned mine and measure and sure enough, it is 56.1 but my wheels still doesn't fit. Thanks guys!
Old 04-02-2015, 10:51 AM   #12
wparsons
wparsons's Avatar
Have you measured the stock wheels to see how accurate your measuring method is, as well as measuring the hub? Have you tried front and rear, or just one corner?
flickr
2015 BRZ Series.Blue STI Turbo 5k miles Manual Fully Loaded + blue LED conversion bren5279 Cars for Sale/Trade 40 04-21-2015 10:32 PM
10 Series / Series.Blue rear view mirror 86-ADL Cosmetic Modification (Interior/Exterior/Lighting) 4 11-16-2014 07:32 PM
BRZ series.blue/FRS Series 1.0 photos Johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-25-2014 11:23 PM
BRZ and FRS will be included to the CDC Small Bore Series echan Mid-Atlantic 6 01-08-2014 02:22 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
